Topic: Easy VR Shield 3 HELP! (Read 5081 times) previous topic - next topic
Marcos122122
Oct 10, 2015, 05:55 pm Last Edit: Oct 17, 2015, 05:21 pm by Marcos122122
Hello. I need help for a project I 'm doing with vr and Arduino easy . When compiling the code and open the serial monitor I get: "easy vr is not detected "
Help take a lot of time researching but can not find the answer.
Thank's
(I'm using Google Translate)
Code: [Select]
#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
  #error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(SERIAL_PORT_USBVIRTUAL)
  // Shield Jumper on HW (for Leonardo and Due)
  #define port SERIAL_PORT_HARDWARE
  #define pcSerial SERIAL_PORT_USBVIRTUAL
#else
  // Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
  #include "SoftwareSerial.h"
  SoftwareSerial port(12, 13);
  #define pcSerial SERIAL_PORT_MONITOR
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_1  = 1,
  GROUP_16 = 16,
enum Group1
  G1_ENCENDER_LAMPARA = 0,
  G1_APAMAR_LAMPARA = 1,
enum Group16
  G16_INDAHAUS = 0,
int8_t group, idx;
  // setup PC serial port
  pcSerial.begin(9600);
  // bridge mode?
  int mode = easyvr.bridgeRequested(pcSerial);
  switch (mode)
  case EasyVR::BRIDGE_NONE:
    // setup EasyVR serial port
    port.begin(9600);
    // run normally
    pcSerial.println(F("---"));
    pcSerial.println(F("Bridge not started!"));
  case EasyVR::BRIDGE_NORMAL:
    // setup EasyVR serial port (low speed)
    port.begin(9600);
    // soft-connect the two serial ports (PC and EasyVR)
    easyvr.bridgeLoop(pcSerial);
    // resume normally if aborted
    pcSerial.println(F("Bridge connection aborted!"));
  case EasyVR::BRIDGE_BOOT:
    // setup EasyVR serial port (high speed)
    port.begin(115200);
  while (!easyvr.detect())
    Serial.println("EasyVR not detected!");
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(4);
  group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()
    switch (group)
    case GROUP_1:
      switch (idx)
      case G1_ENCENDER_LAMPARA:
        // write your action code here
        // group = GROUP_X; <-- or jump to another group X for composite commands
      case G1_APAMAR_LAMPARA:
    case GROUP_16:
      switch (idx)
      case G16_INDAHAUS:
If you do not see the code , it is this:
#endif
#else
#endif
#include "EasyVR.h"
enum Groups
  GROUP_1  = 1,
  GROUP_16 = 16,
enum Group1
enum Group16
  G16_INDAHAUS = 0,
int8_t group, idx;
  // bridge mode?
  switch (mode)
    port.begin(9600);
    // run normally
    port.begin(9600);
    port.begin(115200);
void action();
  do
  if (idx >= 0)
    return;
  if (idx >= 0)
    uint8_t train = 0;
    char name[32];
    Serial.print(idx);
    action();
    if (err >= 0)
void action()
    switch (group)
    case GROUP_1:
      switch (idx)
    case GROUP_16:
      switch (idx)
      case G16_INDAHAUS:
PaulS
Quote
Which Arduino? How IS the VR connected?
Marcos122122
#2
Oct 14, 2015, 06:57 pm Last Edit: Oct 15, 2015, 06:29 pm by Marcos122122
 i'm using Arduino Leonardo and connect with the Quick USB cable.
Marcos122122
PaulS
I don't see a link to the VR module you are using.
Marcos122122
use the bridge on SW in the Easy VR sheield.
DuaneDegn
The Program EasyVR Commander has a drop down box where you need to select the com port. Make sure the correct port is selected.
It looks like the EasyVR shield includes some jumpers. Have you set these for the Leonardo? A picture of your setup might help us find a problem.
It's possible to communicate with EasyVR without an Arduino if you have a serial to USB adapter. Do you have a serial to USB adapter to use as an alternative to the Arduino?
Do you have any other Arduino boards?
Marcos122122
I have a Quick USB cable but, i don't have another arduino board.
I upload a photo un 2 hours.
Marcos122122
Easy VR + Arduino Leonardo:
PaulS
I'll write up a response on a wet paper towel, and post a fuzzy, poorly lit, picture of that. When I get around to it.
DuaneDegn
It looks like for the Leonardo you need to follow the directions on the bottom half of page 22 of the user manual. This is a link to the pdf.
I believe you have the jumper in the wrong position. According to page 22 you should use the "HW" position.
Marcos122122
I've already done but nothing , I get into the serial port but it say if easyVR is not detected.
DuaneDegn
Did you try the "Test Shield with Arduino" section on page 22? Did you send a question mark? What did the terminal window display?
