Topic: "Read-only file system" on /mnt/sda1 after factory reset (Read 968 times) previous topic - next topic
supersleeper
Hi Folks,
This is the first I've run into this issue as I've factory reset the Yun about 4 times now.
root@330ci:/mnt/sda1/arduino/www/logs# mkdir test
mkdir: can't create directory 'test': Read-only file system
and plenty of space, with nothing consuming CPU in top:
root@330ci:/mnt/sda1/arduino/downloads# df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                    6.9M      1.8M      5.1M  26% /
/dev/root                 7.5M      7.5M         0 100% /rom
tmpfs                    29.8M    436.0K     29.4M   1% /tmp
tmpfs                   512.0K         0    512.0K   0% /dev
/dev/mtdblock3            6.9M      1.8M      5.1M  26% /overlay
overlayfs:/overlay        6.9M      1.8M      5.1M  26% /
/dev/sda1                29.8G    787.2M     29.0G   3% /mnt/sda1
supersleeper
Well, not sure what caused this but a reboot fixed it.
molviken
Hi! This just happened to me aswell, new factory reset or just a reboot doesn't help. Any suggestions?
It used to be write also, as I  have created a folder there, but cannot do anything anymore.
