Topic: Connecting CLRC663 to Arduino (Read 1 time) previous topic - next topic
dani91ro
Hello,
I want to connect an CLRC663 module to arduino but i have a problem receiving data from CLRC663, the module recognize the tag, but in arduino i am not receiving anything.
This is the datasheet of the module: http://www.nxp.com/documents/data_sheet/CLRC663.pdf
This is the code what i am using:
#include <Wire.h>
#include <EEPROM.h>
// There are 512 bytes of EEPROM available. The data stored there
//remains when the Arduino is switched off or reset
// Each tag uses 5 bytes (1 byte status, 4 bytes tag number),
//so 512 / 5 = 102 cards may be stored
#define MAX_NO_CARDS 102
// define the LED pins:
#define waitingLED 7
#define successLED 8
#define failureLED 9
int toggleState = 0;    // state of the toggling LED
long toggleTime = 0;    // delay time of the toggling LED
byte tag[4];            // tag serial numbers are 4 bytes long
  Wire.begin();                      // join i2c bus
  Serial.begin(9600);                // set up serial port
  Wire.beginTransmission(0x28);      // the RFID reader's address is 42
  Wire.write(0x00);                   // Length
  Wire.write(0x1F);                   // reset reader
  Wire.endTransmission();
  // initialize the LEDs:
  pinMode(waitingLED, OUTPUT);
  pinMode(successLED, OUTPUT);
  pinMode(failureLED, OUTPUT);
  // print user instructions serially:
  Serial.println("n - add card to database");
  Serial.println("c - clear entire database");
  Serial.println("d - delete card from database");
  Serial.println("p - print database");
  // delay to allow reader startup time:
  delay(2000);
  if (Serial.available() > 0) {
    // read the latest byte:
    char incomingByte = Serial.read();
    switch (incomingByte) {
    case 'n':            // if user enters 'n' then store tag number
      seekNewTag();
    case 'c':
      eraseEEPROM();    // if user enters 'c' then erase database
      Serial.println("Database deleted");
    case 'd':           // if user enters 'd' then delete the last tag
      seekAndDeleteTag();
    case'p':            // if user enters 'p' then print the database
      printTags();
  else {
    //if there's no serial data coming in,
    // the default action is to seek new tags:
    seekNewTag();
  // delay before next command to the reader:
  delay(200);
// erase the entire EEPROM memory storage:
void eraseEEPROM(){
  for(int i = 0; i < 512; i++){
    EEPROM.write(i, 0);
// writes tag number in a location:
void writeTag(int startingAddress, byte byte0, byte byte1, byte byte2, byte byte3){
  EEPROM.write( startingAddress*5, byte(1));
  EEPROM.write(startingAddress*5+1, byte0);
  EEPROM.write(startingAddress*5+2, byte1);
  EEPROM.write(startingAddress*5+3, byte2);
  EEPROM.write(startingAddress*5+4, byte3);
// delete tag from a specified location
void deleteTag(int startingAddress){
  EEPROM.write( startingAddress*5, byte(0));
  EEPROM.write(startingAddress*5+1, byte(0));
  EEPROM.write(startingAddress*5+2, byte(0));
  EEPROM.write(startingAddress*5+3, byte(0));
  EEPROM.write(startingAddress*5+4, byte(0));
// find the first empty entry in the database:
int findEmptyTag(){
  for (int startingAddress = 0; startingAddress< MAX_NO_CARDS; startingAddress++){
    byte value = EEPROM.read(startingAddress*5);
    if (value == byte(0)) {
      return(startingAddress);
  return(200);
// print the entire database
void printTags(){
  for (int thisTag = 0; thisTag< MAX_NO_CARDS; thisTag++){
    printOneTag(thisTag);
void printOneTag(int address) {
  Serial.print(address);
  Serial.print(":");
  for (int offset = 1; offset < 5; offset++) {
    int thisByte = int(EEPROM.read(address*5+offset));
    // if the byte is less than 16, i.e. only one hex character
    // add a leading 0:
    if (thisByte < 0x10) {
      Serial.print("0");
    // print the value:
    Serial.print(thisByte,HEX);
  // add a final linefeed and carriage return:
//lookup tag in the database:
int lookupTag(byte byte0, byte byte1, byte byte2, byte byte3){
  for (int thisCard = 0; thisCard< MAX_NO_CARDS; thisCard++){
    byte value = EEPROM.read(thisCard*5);
    if (value != byte(0)){                    //it is a valid tag
      //see if all four bytes are the same as the ones we're looking for
      if(byte0 == EEPROM.read(thisCard*5+1) && byte1 == EEPROM.read(thisCard*5+2)
        && byte2 == EEPROM.read(thisCard*5+3) && byte3 == EEPROM.read(thisCard*5+4)) {
        return(thisCard);
  // if you don't find the tag, return 200;
  return(200);
int getTag(){
  byte count = 0;
  byte valid = 0;
  byte byteFromReader = 0;
  Wire.write(0x01);           // Length
  Wire.write(0x82);           // Seek for tags
  Wire.write(0x83);           // Checksum
  delay(100);
  Wire.requestFrom(0x28, 8); // get data (8 bytes) from reader
  count = 0;                 // keeps track of which byte it is in the response from the reader
  valid = 0;                 // used to indicate that there is a tag there
  while(Wire.available())  { // while data is coming from the reader
    byteFromReader = Wire.read();
    // no RFID found: reader sends character 2:
    if ((count == 0) && (byteFromReader == 2)) {
      return(0);
    if ((count == 0) && (byteFromReader== 6)) {
      //if reader sends 6, the tag serial number is coming:
      valid = 1;
    count++;
    if ((valid == 1) && (count > 3) && (count < 8)) {
      // strip out the header bytes  :
      tag[count-4] = byteFromReader;
    // all four bytes received: tag serial number complete:
    if ((valid == 1) && (count == 8)) {
      return(1);
void seekNewTag() {
  Serial.println("Waiting for card");
  while(getTag() == 0){
    // wait for tag
    if (millis() - toggleTime > 1000) {
      toggle(waitingLED);
      toggleTime  = millis();
    // unless you get a byte of serial data,
    if (Serial. available()) {
      // break out of the while loop
      // and out of the seekNewTag() method:
      return;
  blink(successLED, 100, 1);
  // look it up in the database:
  int tagToCheck = lookupTag(tag[0], tag[1], tag[2], tag[3]);
  if (tagToCheck != 200){
    Serial.println("That tag is already stored");
    printOneTag(tagToCheck);
  else {
    int emptyTagLocation = findEmptyTag();
    if (emptyTagLocation != 200){
      writeTag(emptyTagLocation, tag[0], tag[1], tag[2], tag[3]);
      Serial.println("That tag is new");
      printOneTag(emptyTagLocation);
    else {
      Serial.println("Maximum number of cards stored");
      blink(failureLED, 50, 10);
void seekAndDeleteTag() {
  Serial.println("Deleting the next card");
    // do nothing; wait for tag
      // and out of the method:
      return;
  int tagToDelete = lookupTag(tag[0], tag[1], tag[2], tag[3]);
  if (tagToDelete == 200){
    Serial.print("That tag is not stored");
  else {
    deleteTag(tagToDelete);
void toggle(int thisLED) {
  toggleState = !toggleState;
  digitalWrite(thisLED, toggleState);
void blink(int thisLED, int interval, int count) {
  for (int i = 0; i < count; i++) {
    digitalWrite(thisLED, HIGH);
    delay(interval/2);
    digitalWrite(thisLED, LOW);
    delay(interval/2);
PaulS
Quote
How DID you connect it? Hopefully you did a better job of that than you did of reading the stickies at the top of the forum, the ones that say read this BEFORE posting code incorrectly.
1vav
