Topic: MIDI to Solenoid help? (Read 911 times) previous topic - next topic
whatsjimmy
after loads of searching through the forums i can't seem to find anything that fully explain how to achieve this? Ive saw loads of people doing it so i know it can be done such as this video..
https://www.youtube.com/watch?v=hlbGDJs8Yms
And lots of other examples, but I'm not sure where to start?
I have an uno will this work?
I purchased a solenoid to get going as well as a midi shield if needed but not quite sure how to get everything going in-between?
Any help would be great! thanks!
Grumpy_Mike
whatsjimmy
See this full write up:-
http://www.thebox.myzen.co.uk/Hardware/Glockenspiel.html
Yea this seems to be the only one that pops up around here. There's so many questions that arise when reading through that one. Is that a DIY shield? Which arduino board is used? Etc
Grumpy_Mike
Quote
I did that one, so ask away:-
Quote
Yes
Quote
Any. I used a Arduino duemilanove but a Uno will do just as well.
Quote
Etc
Ask.
whatsjimmy
Ok thanks. Will your code work with my shield...
https://www.olimex.com/Products/Duino/Shields/SHIELD-MIDI/open-source-hardware
Grumpy_Mike
Quote
Yes the code is not hardware dependent on the MIDI / Arduino interface side. In fact it is hard to see how any code could be sensitive to that.
MIDI is a serial protocol and as such is handled in exactly the same way as any serial data on an Arduino.
whatsjimmy
Its just my understanding of the whole thing. Without sidetracking everything you've said etc. Do you know if the Maxuino setup would be easier for this?
nickgammon
The account for whatsjimmy has been deleted at his request. His posts remain.
- Moderator
Note: This is because he wanted to rename his account, which the forum doesn't let him or us do. <sigh>
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
