Topic: How frequently is it okay to call Bridge.put() (Read 436 times) previous topic - next topic
timex40
I have a sketch that is pushing sensor values to the Linux side of the Yun using Bridge.put()
For example my loop function would include:
    value = analogRead(sensorPin);
    Bridge.put('Sensor_val', String(value));
My question is what is the minimum delay() that should be used in this loop?
Is there any problems with putting a delay(100) in there so that Bridge.put() is called 10x per second? Is there any problems with doing it faster than that?
dalver
You can do it without any delays - Bridge.put is blocking function which transfer your string code to OpenWRT by Serial1 with 250k speed.
