Topic: Atmega2561 (Read 7397 times) previous topic - next topic
somedude
Sorry, Bob, this may be too little too late, but I promised to post the pins file for the waspmote and here it is:
Code: [Select]
 *  Copyright (c) 2005 David A. Mellis
 * Revised for Waspmote by D. Cuartielles & A. Bielsa, 2009
 * Revised for Waspmote by Libelium, 2014
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU Lesser General Public License as published by
 *  the Free Software Foundation, either version 2.1 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU Lesser General Public License for more details.
 *  You should have received a copy of the GNU Lesser General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version: 1.0
 *  Design: David Gascón
 *  Implementation: D.Mellis, D. Cuartielles, A. Bielsa, Y. Carmona
#ifndef Pins_Waspmote_h
#define Pins_Waspmote_h
#include <avr/pgmspace.h>
// GIVE NAMES TO THE WHOLE PINOUT FOR WASP
// DESCRIPTION WASP API PIN PORT PIN WASP API PIN DESCRIPTION
#define USB_XBEE_RX 0 // PE 0 ** 0 ** USB_XBEE_RX
#define USB_XBEE_TX 1 // PE 1 ** 1 ** USB_XBEE_TX
#define DIGITAL1 2 // PE 3 ** 2 ** DIGITAL1        -- PWM1 BEFORE
#define DIGITAL0 3 // PE 4 ** 3 ** DIGITAL0        -- PWM2 BEFORE
#define DIGITAL7 4 // PC 4 ** 4 ** DIGITAL7        -- DIG0 BEFORE
#define DIGITAL8 5 // PC 5 ** 5 ** DIGITAL8        -- DIG1 BEFORE
#define DIGITAL6 6 // PC 6 ** 6 ** DIGITAL6        -- DIG2 BEFORE
#define DIGITAL5 7 // PC 7 ** 7 ** DIGITAL5        -- DIG3 BEFORE
#define DIGITAL2 8 // PA 2 ** 8 ** DIGITAL2        -- DIG4 BEFORE
#define DIGITAL4 9 // PA 3 ** 9 ** DIGITAL4        -- DIG5 BEFORE
#define DIGITAL3 10 // PA 4 ** 10 ** DIGITAL3        -- DIG6 BEFORE
#define MUX_USB_XBEE 11 // PD 5 ** 11 ** DIGITAL9        -- DIG7 BEFORE
#define LED0 12 // PD 6 ** 12 ** LED0
#define LED1 13 // PC 1 ** 13 ** LED1
#define ANA0 14 // PF 1 ** 14 ** ANA0
#define ANA1 15 // PF 2 ** 15 ** ANA1
#define ANA2 16 // PF 3 ** 16 ** ANA2
#define ANA3 17 // PF 4 ** 17 ** ANA3
#define ANA4 18 // PF 5 ** 18 ** ANA4
#define ANA5 19 // PF 6 ** 19 ** ANA5
#define ANA6 20 // PF 7 ** 20 ** ANA6
#define BAT_MONITOR 21 // PF 0 ** 21 ** BAT_MONITOR
#define XBEE_PW 22 // PA 1 ** 22 ** XBEE_PW
#define MUX_PW 23 // PD 7 ** 23 ** MUX_PW
#define SENS_PW_5V 24 // PE 5 ** 24 ** SENS_PW_5V
#define BAT_MONITOR_PW 25 // PA 6 ** 25 ** BAT_MONITOR_PW
#define SENS_PW_3V3 26 // PE 2 ** 26 ** SENS_PW_3v3
#define MEM_PW 27 // PA 5 ** 27 ** MEM_PW
#define SD_PRESENT 28 // PC 0 ** 28 ** SD_PRESENT
#define SD_SS 29 // PB 0 ** 29 ** SD_SS
#define SD_SCK 30 // PB 1 ** 30 ** SD_SCK
#define SD_MOSI 31 // PB 2 ** 31 ** SD_MOSI
#define SD_MISO 32 // PB 3 ** 32 ** SD_MISO
#define HIB_PIN 33 // PB 4 ** 33 ** SERID_PW
#define SOCKET0_SS 34 // PB 5 ** 34 ** SERID_IN
#define GPS_PW 35 // PA 0 ** 35 ** GPS_PW
#define MUX_0 36 // PB 6 ** 36 ** MUX_0
#define MUX_1 37 // PB 7 ** 37 ** MUX_1
#define RDY_ACC 38 // PE 6 ** 38 ** RDY_ACC
#define RST_RTC 39 // PE 7 ** 39 ** RST_RTC
#define I2C_SCL 40 // PD 0 ** 40 ** I2C_SCL
#define I2C_SDA 41 // PD 1 ** 41 ** I2C_SDA
#define GPRS_PW 42 // PC 3 ** 42 ** GPRS_PW
#define MUX_RX 43 // PD 2 ** 43 ** GPS/GPRS/SER1/SER2_RX
#define MUX_TX 44 // PD 3 ** 44 ** GPS/GPRS/SER1/SER2_TX
#define XBEE_MON 45 // PA 7 ** 45 ** XBEE_MON
#define GPRS_PIN 46 // PC 2 ** 46 ** GPRS_PIN
#define XBEE_SLEEP 47 // PD 4 ** 47 ** XBEE_SLEEP
#define RTC_PW 48 // PG 2 ** 48 ** RTC_PW
#define RTC_SLEEP 49 // PG 1 *** 49 ** RTC_SLEEP
#define LOW_BAT_MON 50 // PG 0 ** 50 ** LOW_BAT_MON
#define NOT_A_PIN 0
#define NOT_A_PORT 0
#define NOT_ON_TIMER 0
#define TIMER0A 1
#define TIMER0B 2
#define TIMER1A 3
#define TIMER1B 4
#define TIMER2  5
#define TIMER2A 6
#define TIMER2B 7
#define TIMER3A 8
#define TIMER3B 9
#define TIMER3C 10
extern const uint8_t PROGMEM port_to_mode_PGM[];
extern const uint8_t PROGMEM port_to_input_PGM[];
extern const uint8_t PROGMEM port_to_output_PGM[];
extern const uint8_t PROGMEM digital_pin_to_port_PGM[];
extern const uint8_t PROGMEM digital_pin_to_bit_PGM[];
extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[];
extern const uint8_t PROGMEM digital_pin_to_timer_PGM[];
// Get the bit location within the hardware port of the given virtual pin.
// This comes from the pins_*.c file for the active board configuration.
// These perform slightly better as macros compared to inline functions
#define digitalPinToPort(P) ( pgm_read_byte( digital_pin_to_port_PGM + (P) ) )
#define digitalPinToBitMask(P) ( pgm_read_byte( digital_pin_to_bit_mask_PGM + (P) ) )
#define digitalPinToTimer(P) ( pgm_read_byte( digital_pin_to_timer_PGM + (P) ) )
#define analogInPinToBit(P) (P)
#define portOutputRegister(P) ( (volatile uint8_t *)( (uint16_t)pgm_read_byte( (port_to_output_PGM + (P)))) )
#define portInputRegister(P) ( (volatile uint8_t *)( (uint16_t)pgm_read_byte( port_to_input_PGM + (P))) )
#define portModeRegister(P) ( (volatile uint8_t *)( (uint16_t)pgm_read_byte( port_to_mode_PGM + (P))) )
#endif
CrossRoads
Yes, I already have what appears to be a working pins_arduino.h, with ports mapped to consecutive pin #s, and pin names all done up nice & pretty on the board.
Well, it compiled Blink ok, that's all I've done so far.
That shows 10 timers - where are 2A and 2B coming from? I don't see OC2B, OC2C in Figure 1-3 of the Oct 2014 2560/2561 datasheet.
This makes me wonder if more info, or another file, is needed tho, or needs to be looked into:
somedude
Oops, sorry, yes, here it is (pins_waspmote.c), part 1 of 2 (exceeds 9000 chars:
Code: [Select]
 *  Version: 1.0
#include <avr/io.h>
#include "wiring_private.h"
#include "pins_waspmote.h"
// On the Wasp board, digital pins are also used
// for the analog output (software PWM).  Analog input
// pins are a separate set.
// ATMEL ATMEGA1281 / WASP
//                               A  G  A  P  P  P  P  P  P  P  P  G  V  P  P  P
//                               V  N  R  F  F  F  F  F  F  F  F  N  C  A  A  A
//                               C  D  F  0  1  2  3  4  5  6  7  D  C  0  1  2
//                              _64_63_62_61_60_59_58_57_56_55_54_53_52_51_50_49__
//                             /O                                                 |
//   (   )             PG5   1|                                                   |48 PA3
//   (D 0)             PE1   2|                                                   |47 PA4
//   (   )             PE1   3|                                                   |46 PA5
//   (   )             PE2   4|                                                   |45 PA6
//   (   )             PE3   5|                                                   |44 PA7
//   (   )             PE4   6|                                                   |43 PG2
//   (   )             PE5   7|                                                   |42 PC7
//   (   )             PE6   8|                                                   |41 PC6
//   SOFT LED (LED4) - PE7   9|                                                   |40 PC5
//   (   )             PB0  10|                                                   |39 PC4
//   (   )             PB1  11|                                                   |38 PC3
//   (   )             PB2  12|                                                   |37 PC2
//   (   )             PB3  13|                                                   |36 PC1 - SOFT LED (LED3)
//   (   )             PB4  14|                                                   |35 PC0
//   (   )             PB5  15|                                                   |34 PG1
//   (   )             PB6  16|                                                   |33 PG0
//                            |___________________________________________________|
//                               17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
//                               P  P  P  R  V  G  X  X  P  P  P  P  P  P  P  P
//                               B  G  G  S  C  N  T  T  D  D  D  D  D  D  D  D
//                               7  3  4  T  C  D  2  1  0  1  2  3  4  5  6  7
#define PA 1
#define PB 2
#define PC 3
#define PD 4
#define PE 5
#define PF 6
#define PG 7
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint8_t PROGMEM port_to_mode_PGM[] = {
NOT_A_PORT,
(uint16_t)&DDRA,
(uint16_t)&DDRB,
(uint16_t)&DDRC,
(uint16_t)&DDRD,
(uint16_t)&DDRE,
(uint16_t)&DDRF,
(uint16_t)&DDRG,
const uint8_t PROGMEM port_to_output_PGM[] = {
NOT_A_PORT,
(uint16_t)&PORTA,
(uint16_t)&PORTB,
(uint16_t)&PORTC,
(uint16_t)&PORTD,
(uint16_t)&PORTE,
(uint16_t)&PORTF,
(uint16_t)&PORTG,
const uint8_t PROGMEM port_to_input_PGM[] = {
NOT_A_PORT,
(uint16_t)&PINA,
(uint16_t)&PINB,
(uint16_t)&PINC,
(uint16_t)&PIND,
(uint16_t)&PINE,
(uint16_t)&PINF,
(uint16_t)&PING,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
// PORT PIN WASP API PIN DESCRIPTION
PE , // PE 0 ** 0 ** USB_XBEE_RX
PE , // PE 1 ** 1 ** USB_XBEE_TX
PE , // PE 3 ** 2 ** DIGITAL1
PE , // PE 4 ** 3 ** DIGITAL0
PC , // PC 4 ** 4 ** DIGITAL7
PC , // PC 5 ** 5 ** DIGITAL8
PC , // PC 6 ** 6 ** DIGITAL6
PC , // PC 7 ** 7 ** DIGITAL5
PA , // PA 2 ** 8 ** DIGITAL2
PA , // PA 3 ** 9 ** DIGITAL4
PA , // PA 4 ** 10 ** DIGITAL3
PD , // PD 5 ** 11 ** DIGITAL9
PD , // PD 6 ** 12 ** LED0
PC , // PC 1 ** 13 ** LED1
PF , // PF 1 ** 14 ** ANA0
PF , // PF 2 ** 15 ** ANA1
PF , // PF 3 ** 16 ** ANA2
PF , // PF 4 ** 17 ** ANA3
PF , // PF 5 ** 18 ** ANA4
PF , // PF 6 ** 19 ** ANA5
PF , // PF 7 ** 20 ** ANA6
PF , // PF 0 ** 21 ** BAT_MONITOR
PA , // PA 1 ** 22 ** XBEE_PW
PD , // PD 7 ** 23 ** XBEE SLEEP
PE , // PE 5 ** 24 ** SENS_PW_5V
PA , // PA 6 ** 25 ** BAT_MONITOR_PW
PE , // PE 2 ** 26 ** SENS_PW_3v3
PA , // PA 5 ** 27 ** MEM_PW
PC , // PC 0 ** 28 ** SD_PRESENT
PB , // PB 0 ** 29 ** SD_SS
PB , // PB 1 ** 30 ** SD_SCK
PB , // PB 2 ** 31 ** SD_MOSI
PB , // PB 3 ** 32 ** SD_MISO
PB , // PB 4 ** 33 ** SERID_PW
PB , // PB 5 ** 34 ** SERID_IN
PA , // PA 0 ** 35 ** GPS_PW
PB , // PB 6 ** 36 ** GPS_RX
PB , // PB 7 ** 37 ** GPS_TX
PE , // PE 6 ** 38 ** RDY_ACC
PE , // PE 7 ** 39 ** RST_RTC
PD , // PD 0 ** 40 ** I2C_SCL
PD , // PD 1 ** 41 ** I2C_SDA
PC , // PC 3 ** 42 ** GPRS_PW
PD , // PD 2 ** 43 ** GPRS_RX
PD , // PD 3 ** 44 ** GPRS_TX
PA , // PA 7 ** 45 ** BOOT PIN
PC , // PC 2 ** 46 ** PWON
PD , // PD 4 ** 47 ** FREE PIN
PG , // PG 2 ** 48 ** RTC_PW
PG , // PG 1 ** 49 ** RTC_SLEEP
  PG , // PG 0 ** 50 ** LOW_BAT_MON
somedude
2 of 2:
Code: [Select]
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
// PIN PORT PIN WASP API PIN DESCRIPTION
_BV( 0 ) , // PE 0 ** 0 ** USB_XBEE_RX
_BV( 1 ) , // PE 1 ** 1 ** USB_XBEE_TX
_BV( 3 ) , // PE 3 ** 2 ** DIGITAL1
_BV( 4 ) , // PE 4 ** 3 ** DIGITAL0
_BV( 4 ) , // PC 4 ** 4 ** DIGITAL7
_BV( 5 ) , // PC 5 ** 5 ** DIGITAL8
_BV( 6 ) , // PC 6 ** 6 ** DIGITAL6
_BV( 7 ) , // PC 7 ** 7 ** DIGITAL5
_BV( 2 ) , // PA 2 ** 8 ** DIGITAL2
_BV( 3 ) , // PA 3 ** 9 ** DIGITAL4
_BV( 4 ) , // PA 4 ** 10 ** DIGITAL3
_BV( 5 ) , // PD 5 ** 11 ** DIGITAL9
_BV( 6 ) , // PD 6 ** 12 ** LED0
_BV( 1 ) , // PC 1 ** 13 ** LED1
_BV( 1 ) , // PF 1 ** 14 ** ANA0
_BV( 2 ) , // PF 2 ** 15 ** ANA1
_BV( 3 ) , // PF 3 ** 16 ** ANA2
_BV( 4 ) , // PF 4 ** 17 ** ANA3
_BV( 5 ) , // PF 5 ** 18 ** ANA4
_BV( 6 ) , // PF 6 ** 19 ** ANA5
_BV( 7 ) , // PF 7 ** 20 ** ANA6
_BV( 0 ) , // PF 0 ** 21 ** BAT_MONITOR
_BV( 1 ) , // PA 1 ** 22 ** XBEE_PW
_BV( 7 ) , // PD 7 ** 23 ** XBEE SLEEP
_BV( 5 ) , // PE 5 ** 24 ** SENS_PW_5V
_BV( 6 ) , // PA 6 ** 25 ** BAT_MONITOR_PW
_BV( 2 ) , // PE 2 ** 26 ** SENS_PW_3v3
_BV( 5 ) , // PA 5 ** 27 ** MEM_PW
_BV( 0 ) , // PC 0 ** 28 ** SD_PRESENT
_BV( 0 ) , // PB 0 ** 29 ** SD_SS
_BV( 1 ) , // PB 1 ** 30 ** SD_SCK
_BV( 2 ) , // PB 2 ** 31 ** SD_MOSI
_BV( 3 ) , // PB 3 ** 32 ** SD_MISO
_BV( 4 ) , // PB 4 ** 33 ** SERID_PW
_BV( 5 ) , // PB 5 ** 34 ** SERID_IN
_BV( 0 ) , // PA 0 ** 35 ** GPS_PW
_BV( 6 ) , // PB 6 ** 36 ** GPS_RX
_BV( 7 ) , // PB 7 ** 37 ** GPS_TX
_BV( 6 ) , // PE 6 ** 38 ** RDY_ACC
_BV( 7 ) , // PE 7 ** 39 ** RST_RTC
_BV( 0 ) , // PD 0 ** 40 ** I2C_SCL
_BV( 1 ) , // PD 1 ** 41 ** I2C_SDA
_BV( 3 ) , // PC 3 ** 42 ** GPRS_PW
_BV( 2 ) , // PD 2 ** 43 ** GPRS_RX
_BV( 3 ) , // PD 3 ** 44 ** GPRS_TX
_BV( 7 ) , // PA 7 ** 45 ** BOOT PIN
_BV( 2 ) , // PC 2 ** 46 ** PWON
_BV( 4 ) , // PD 4 ** 47 ** FREE PIN
_BV( 2 ) , // PG 2 ** 48 ** RTC_PW
_BV( 1 ) , // PG 1 ** 49 ** RTC_SLEEP
_BV( 0 ) , // PG 0 ** 50 ** LOW_BAT_MON
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
NOT_ON_TIMER , // PE 0 ** 0 ** USB_XBEE_RX
NOT_ON_TIMER , // PE 1 ** 1 ** USB_XBEE_TX
TIMER3A , // PE 3 ** 2 ** DIGITAL1
TIMER3B , // PE 4 ** 3 ** DIGITAL0
NOT_ON_TIMER , // PC 4 ** 4 ** DIGITAL7
NOT_ON_TIMER , // PC 5 ** 5 ** DIGITAL8
NOT_ON_TIMER , // PC 6 ** 6 ** DIGITAL6
NOT_ON_TIMER , // PC 7 ** 7 ** DIGITAL5
NOT_ON_TIMER , // PA 2 ** 8 ** DIGITAL2
NOT_ON_TIMER , // PA 3 ** 9 ** DIGITAL4
NOT_ON_TIMER , // PA 4 ** 10 ** DIGITAL3
NOT_ON_TIMER , // PD 5 ** 11 ** DIGITAL9
NOT_ON_TIMER , // PD 6 ** 12 ** LED0
NOT_ON_TIMER , // PC 1 ** 13 ** LED1
NOT_ON_TIMER , // PF 1 ** 14 ** ANA0
NOT_ON_TIMER , // PF 2 ** 15 ** ANA1
NOT_ON_TIMER , // PF 3 ** 16 ** ANA2
NOT_ON_TIMER , // PF 4 ** 17 ** ANA3
NOT_ON_TIMER , // PF 5 ** 18 ** ANA4
NOT_ON_TIMER , // PF 6 ** 19 ** ANA5
NOT_ON_TIMER , // PF 7 ** 20 ** ANA6
NOT_ON_TIMER , // PF 0 ** 21 ** BAT_MONITOR
NOT_ON_TIMER , // PA 1 ** 22 ** XBEE_PW
NOT_ON_TIMER , // PD 7 ** 23 ** XBEE SLEEP
NOT_ON_TIMER , // PE 5 ** 24 ** SENS_PW_5V
NOT_ON_TIMER , // PA 6 ** 25 ** BAT_MONITOR_PW
NOT_ON_TIMER , // PE 2 ** 26 ** SENS_PW_3v3
NOT_ON_TIMER , // PA 5 ** 27 ** MEM_PW
NOT_ON_TIMER , // PC 0 ** 28 ** SD_PRESENT
NOT_ON_TIMER , // PB 0 ** 29 ** SD_SS
NOT_ON_TIMER , // PB 1 ** 30 ** SD_SCK
NOT_ON_TIMER , // PB 2 ** 31 ** SD_MOSI
NOT_ON_TIMER , // PB 3 ** 32 ** SD_MISO
NOT_ON_TIMER , // PB 4 ** 33 ** SERID_PW
NOT_ON_TIMER , // PB 5 ** 34 ** SERID_IN
NOT_ON_TIMER , // PA 0 ** 35 ** GPS_PW
NOT_ON_TIMER , // PB 6 ** 36 ** GPS_RX
NOT_ON_TIMER , // PB 7 ** 37 ** GPS_TX
NOT_ON_TIMER , // PE 6 ** 38 ** RDY_ACC
NOT_ON_TIMER , // PE 7 ** 39 ** RST_RTC
NOT_ON_TIMER , // PD 0 ** 40 ** I2C_SCL
NOT_ON_TIMER , // PD 1 ** 41 ** I2C_SDA
NOT_ON_TIMER , // PC 3 ** 42 ** GPRS_PW
NOT_ON_TIMER , // PD 2 ** 43 ** GPRS_RX
NOT_ON_TIMER , // PD 3 ** 44 ** GPRS_TX
NOT_ON_TIMER , // PA 7 ** 45 ** BOOT PIN
NOT_ON_TIMER , // PC 2 ** 46 ** PWON
NOT_ON_TIMER , // PD 4 ** 47 ** FREE PIN
NOT_ON_TIMER , // PG 2 ** 48 ** RTC_PW
NOT_ON_TIMER , // PG 1 ** 49 ** RTC_SLEEP
NOT_ON_TIMER , // PG 0 ** 50 ** LOW_BAT_MON
