J'ai rentré ce code :
// CAPTEUR DE FLEXION 1 BRANCHE SUR L'ENTREE ANALOGIQUE 0
// CAPTEUR DE FLEXION 2 BRANCHE SUR L'ENTREE ANALOGIQUE 1
// POUR LE MOMENT DISONS QUE LE CDF EST PLIE SI degrees > 10
// PENSER A CHANGER 768 ET 853
// initialize serial communications
int valeur(0);
do {int cdf1, degrees;
// read the voltage from the voltage divider (sensor plus resistor)
cdf1 = analogRead(0);
// convert the voltage reading to inches
// the first two numbers are the sensor values for straight (768) and bent (853)
// the second two numbers are the degree readings we'll map that to (0 to 90 degrees)
degrees = map(cdf1, 768, 853, 0, 90);
// note that the above numbers are ideal, your sensor's values will vary
// to improve the accuracy, run the program, note your sensor's analog values
// when it's straight and bent, and insert those values into the above function.
// print out the result
Serial.print("analog input: ");
Serial.print(cdf1,DEC);
Serial.print(" degrees: ");
Serial.println(degrees,DEC);
int cdf2, degrees;
cdf2 = analogRead(1);
degrees = map(cdf2, 768, 853, 0, 90);
Serial.print(cdf2,DEC);
// pause before taking the next reading
delay(100);
} while (cdf1 >=10 && cdf2 <=10); //si l'utilisteur ne fait ni feuille ni pierre ni ciseaux, répéter la question
if (cdf1 >= 3 && cdf2 >= 3) //l'utilisateur fait feuille
int valeur(3); // valeur 3 = le robot doit faire ciseaux
return valeur;
else if (cdf1 >= 10 && cdf2 >= 1O ) //l'utilisateur fait pierre
int valeur(2); // valeur 2 = le robot doit feuille
return valeur;
else if (cdf <= 10 && cdf2 >=10) //l'utilisateur fait ciseaux
int valeur(1); // valeur 1 = le robot doit faire pierre
return valeur;
et j'ai ce message d'erreur :
Arduino : 1.6.5 (Windows 8.1), Carte : "Arduino/Genuino Uno"
calcul_du_degr__du_cdf.ino:65:36: error: invalid suffix "O" on integer constant
calcul_du_degr__du_cdf.ino: In function 'void loop()':
calcul_du_degr__du_cdf.ino:35:11: error: redeclaration of 'int degrees'
calcul_du_degr__du_cdf.ino:16:15: error: 'int degrees' previously declared here
calcul_du_degr__du_cdf.ino:58:18: error: 'cdf1' was not declared in this scope
calcul_du_degr__du_cdf.ino:58:31: error: 'cdf2' was not declared in this scope
calcul_du_degr__du_cdf.ino:63:16: error: return-statement with a value, in function returning 'void' [-fpermissive]
calcul_du_degr__du_cdf.ino:68:16: error: return-statement with a value, in function returning 'void' [-fpermissive]
calcul_du_degr__du_cdf.ino:70:14: error: 'cdf' was not declared in this scope
calcul_du_degr__du_cdf.ino:73:16: error: return-statement with a value, in function returning 'void' [-fpermissive]
Je veux que ma carte arduino sache si le gant avec le capteur de flexion fait pierre, feuille, ou ciseaux
si il fait pierre, il ressort la valeur 2
si il fait feuille, il ressort la valeur 3
si il fait ciseaux, il ressort la valeur 1
pour le moment c'est ce que j'essaie de programmer
ensuite la carte envoi par bluetooth à une autre carte arduino la valeur 1,2 ou 3
selon les valeurs, la carte arduino fait fonctionner 2 servos moteurs pour faire bouger une main robotisée
si elle reçoit la valeur 1, elle fait pierre
valeur 2 -> feuille
valeur 3 ciseaux
Merci pour l'aide !
