Topic: Facing errors in Motor related code! Please help (Read 382 times) previous topic - next topic
Shaurya302000
I have Arduino 1.6.5 . I ran an example program 'Motor test' within 'Robot Control' . using arduino UNO board with a L293D motor shield. Somehow when I verify the program, it gives a lot of errors. What can be the solution for this? If possible can anyone please give me the verified one?
MarkT
You selected 'Arduino Robot Control' as the board type now didn't you?
Robin2
If you want help you need to post your code and post the errors you are getting.
And please use the code button </>
Code: [Select]
so your code looks like this and is easy to copy to a text editor
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Shaurya302000
Code: [Select]
  #include <ArduinoRobot.h>
#include <Wire.h>
#include <SPI.h>
  // initialize the robot
  Robot.begin();
  Robot.motorsWrite(255, 255);  // move forward
  delay(2000);
  Robot.motorsStop();           // fast stop
  Robot.motorsWrite(-255, -255); // backward
  Robot.motorsWrite(0, 0);      // slow stop
  Robot.motorsWrite(-255, 255); // turn left
  delay(2000);
  Robot.motorsWrite(255, -255); // turn right
  delay(2000);
So which board should I select? Because I am operating using Arduino UNO
MarkT
That code works only with the Arduino Robot Control board, as far as I can see.
Shaurya302000
When I selected Robot Control Motor, it got verified and then when I was uploading it to my UNO on which the motor shield is connected, it was not getting uploaded. Any idea how to fix that?
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
MarkT
Its example code for the Arduino Robot board only, that's why its in the Robot Control section of examples.
3dprinter
Presumably, although you do not say what went wrong at the upload, it said avrdude: Yikes!  Invalid device signature or something to that effect. You have to select the actual board you are using, not the one you would like it to be.
The library you specify (that is the 1st line in your example) has to match the addon board you are using. If you are not using the Arduino robot stuff, then use the right motorshield library.
