Topic: Processing Graphs/Arduino (Read 1 time) previous topic - next topic
A0159072
Folks - Can someone point me to example code (Arduino & Processing sketches) that I can give to students in a class to graph numbers generated by a TMP 36 temperature sensor? I've tried several examples on the web that fell apart  - old examples I used a year ago no longer work with new software revisions. Just want to use INTs. In a terrible bind for time this week. Please no blasts just give me a hand or skip it - thanks!
el_supremo
Post an old example that no longer works and maybe someone can tell you what to do to make it work with the current IDE.
Pete
Don't send me technical questions via Private Message.
Robin2
Why not just use the earlier software versions that work?
You can easily have several versions of the Arduino IDE on a PC. (I don't know Processing).
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
A0159072
#3
Oct 25, 2015, 12:19 am Last Edit: Oct 25, 2015, 01:55 pm by robtillaart
Robin,
    Because the school where I teach auto-installs newest versions, and it's tacky to make students in
a "modern" class go backwards. Thanks;
Here is an Arduino sketch that outputs temperature just fine:
Code: [Select]
// Measures temperature and displays on Output Screen
const int temperaturePin = 0;
  float voltage, degreesC, degreesF;
  voltage = getVoltage(temperaturePin);
  degreesC = (voltage - 0.5) * 100.0;
  degreesF = degreesC * (9.0/5.0) + 32.0;
 Serial.print("voltage: ");
  Serial.print(voltage);
  Serial.print("  degrees C: ");
  Serial.print(degreesC);
  Serial.print("  degrees F: ");
  Serial.println(degreesF);
  //Serial.println((degreesF*40)-2700);
  // These statements will print lines of data like this:
  // "voltage: 0.73 deg C: 22.75 deg F: 72.96"
  delay(2); // repeat once per second (change as you wish!)
float getVoltage(int pin)
  return (analogRead(pin) * 0.004882814);
  // This equation converts the 0 to 1023 value that analogRead()
  // returns, into a 0.0 to 5.0 value that is the true voltage
  // being read at that pin.
And here is a Processing sketch that I used previously to graph the temp:
Code: (Processing) [Select]
import processing.serial.*;
Serial myPort;        // The serial port
int xPos = 1;         // horizontal position of the graph
void setup () {
  // set the window size:
  size(1000, 300);
  // List all the available serial ports
  //println(Serial.list());
  myPort = new Serial(this, Serial.list()[5], 9600);
  // don't generate a serialEvent() unless you get a newline character:
  myPort.bufferUntil('\n');
  // set inital background:
  background(0);
void draw ()
  // everything happens in the serialEvent()
void serialEvent (Serial myPort)
  // get the ASCII string:
  String inString = myPort.readStringUntil('\n');
  if (inString != null)
    // trim off any whitespace:
    inString = trim(inString);
    // convert to an int and map to the screen height:
    float inByte = float(inString);
    //println("inByte=",inByte);
    //inByte = map(inByte, 0, 1023, 0, height);
    inByte = map(inByte, 0, 80, 0, height);
    //println("inByte = ",inByte);
    // draw the line:
    stroke(127, 34, 255);
    line(xPos, height, xPos, height - inByte);
    //println("xPos =", xPos,"h=",height, "inByte=",width);
    // at the edge of the screen, go back to the beginning:
    if (xPos >= width)
      xPos = 0;
      background(0);
      // increment the horizontal position:
      xPos++;
I am getting a NaN runtime error on the map statement, and I have gone
round and round for hours to no avail, trying lots of different things.  I just want a simple graph of
temperature changing over time coming in from the Arduino.
Thanks for any and all help. Last year I swear this worked fine and I do not remember any difficulties.
[moderator: added code tags and reformatted some code]
A0159072
Also this example generates NaN with the map function call:
https://www.arduino.cc/en/Tutorial/Graph
Looks like something has just not been updated??
Whandall
The delay was much to short I think
Code: [Select]
  delay(200);
Drawing has to be done in the draw() context
Code: [Select]
boolean newValue = false;
float inValue;
void setup () {
  size(1000, 300);
  myPort = new Serial(this, Serial.list()[0], 115200);
  background(0);
void draw ()
  if (newValue) {
    // draw the line:
    line(xPos, height, xPos, height - inValue);
    //println("xPos =", xPos,"h=",height, "inValue=",width);
    if (xPos >= width)
      xPos = 0;
      background(0);
      xPos++;
    newValue = false;
  if (inString != null) {
    inValue = float(inString);
    //println("inValue=",inValue);
    inValue = map(inValue, 0, 1023, 0, height);
    //inValue = map(inValue, 0, 80, 0, height);
    //println("inValue = ",inValue);
    newValue = true;
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
Robin2
Robin,
It might be a great opportunity to demonstrate to your students the difference between "movement" and "progress".
...R
pert
  • Format your code properly(Tools > Auto Format) - This can help you identify issues in your code and makes it much easier for others to read it as well.
  • Use code tags in your forum posts. Help us to help you.
