Topic: Clap clap toggle - getting clap duration (Read 748 times) previous topic - next topic
--Smigol--
First of all - nice to meet you all guys, I'm a new user on this forum and a new user to arduino.
I'm trying to toggle a led (called SWITCH in the sketch) using a microphone i bought, that outputs LOW when receiving a sound, and HIGH when it's not. I can change it's sensitivity using a potentiometer.
My problem is that the code doesn't work well - it doesn't calculate the duration of the clap sound well. I suppose it's an error with the while() use logic.
Here's the code:
Code: [Select]
#define MIC 12
#define SWITCH 11
unsigned long time[3], temp;
void setup(){
  pinMode(MIC, INPUT);
  pinMode(SWITCH, OUTPUT);
  digitalWrite(SWITCH, LOW);
void loop(){
  if(!digitalRead(MIC)){
    temp=millis();
    while(!digitalRead(MIC)){}
    time[0]= millis()-temp;
    Serial.print("Time0: ");
    Serial.println(time[0]);
    temp = millis();
    if(time[0]<10){
      while(digitalRead(MIC)){}
      time[1] = millis()-temp;
      Serial.print("Time1: ");
      Serial.println(time[1]);
      temp = millis();
      if((time[1]>150) && (time[1]<600)){
        time[2] = millis()-temp;
        Serial.print("Time2: ");
        Serial.println(time[2]);
        if(time[2]<10){
          digitalWrite(SWITCH, !digitalRead(SWITCH));
          Serial.println("TOGGLE SWITCH");
        }else{
          Serial.println("TIME2 TOO HIGH");
      }else{
        Serial.println("TIME1 TOO HIGH or TOO LOW");
    }else{
      Serial.println("TIME0 TOO HIGH");
And here a sample serial output:
Code: [Select]
Time0: 0
Time1: 0
Time0: 0
Time1: 0
Time0: 3
Time1: 0
Time0: 0
Time1: 0
Sometimes the LED does toggle, but usually it doesn't.
PaulS
Why are you attempting to re-implement the pulseIn() function?
Blue Eyes
It seems like you would have to have amazing timing on your claps to light the LED.  I recommend that you change each if statement that checks the time array to not check and just flow right through like this:
Code: [Select]
if( true /*time[0]<10*/  ){
This way you will see what values are printed out for each clap, the numbers might be  different than you expect.
