Topic: Trying to get motor to turn on at specific time (Read 3802 times) previous topic - next topic
Delta_G
#15
Nov 15, 2015, 12:22 am Last Edit: Nov 15, 2015, 12:28 am by Delta_G
SMDH!
Do you not get that you can't assign something to a function call?  Trying to assign something negative isn't going to work any better than trying to assign something positive.
You have to be willing to think a little or this is going to get real old real quick.
Go look at the Blink Without Delay example and see how that line should be written.
Or hell, look a few lines up in the code @BulldogLowell gave you and see the other place where he used that technique.
You can't assign anything to a function call.  You can subtract something from the value it returns.  Does that clue you in?
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
mbasile
i figured it out as soon as i posted but it wouldnt let me edit my post since i had already posted to much in 10 minutes or whatever.
code is currently
however i set the time to 626 and 1826 to get the the motor to turn, but it did not do so at the specified time...
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
RTC_DS1307 RTC;
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
int motorPin = 9;
int lastHour = 24;
bool feedPet = false;
unsigned long feedTime = 0;
unsigned long lastPrintTime = 0;
void setup ()
  pinMode(motorPin, OUTPUT);
  lcd.begin(16, 2);
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
    lcd.println("RTC NOT Running!");
    RTC.adjust(DateTime((__DATE__), (__TIME__)));
void loop ()
  DateTime now = RTC.now();
  int currentHour = now.hour();
  if (lastHour != currentHour && (currentHour == 626 || currentHour == 1826)) // if the hour just changed to 6 or 18
    feedTime = millis();
    feedPet = true;
    lastHour = currentHour;
  if (feedPet)
    turnFeeder();
  lcd.setCursor(0, 1);
  lcd.print("Time: ");
    lcd.print(now.hour(), DEC);
    lcd.print(":");
    lcd.print(now.minute(), DEC);
    lcd.print(":");
    lcd.print(now.second(), DEC);
    lcd.print(" ");
  if (millis() - lastPrintTime > 1000UL)
    lcd.setCursor(0, 0);
    lcd.print("DATE: ");
    lcd.print(now.month(), DEC);
    lcd.print("/");
    lcd.print(now.day(), DEC);
    lcd.print("/");
    lcd.print(now.year(), DEC);
    lastPrintTime = millis();
void turnFeeder(void)
  static byte pinState = HIGH;
  if (millis() - feedTime < 6000UL) // 60 seconds
    if (pinState = HIGH)
      digitalWrite(motorPin, pinState);
      pinState = LOW;
    pinState = HIGH;
    feedPet = false;
Delta_G
#17
Nov 15, 2015, 12:32 am Last Edit: Nov 15, 2015, 12:33 am by Delta_G
Code: [Select]
OK, so on my planet there are only 24 hours in a day.  Where do you live that there are more than 1826 hours in one day?
|| | ||| | || | ||  ~Woodstock
mbasile
what should i enter then for the time if it was say 6:38pm? thats 1838hrs military time, thats why i put that, obviously i was wrong.
PaulS
#19
Nov 15, 2015, 12:40 am Last Edit: Nov 15, 2015, 12:45 am by PaulS
Damn, you beat me to it.That was the exact question I was going to ask.
PaulS
Quote
No, it is not one thousand, eight hundred thirty eight hours.
The value from now.hour() will be between 0 and 23. The value from now.minute() will be between 0 and 59. You have to use a compound if statement.
Delta_G
Well, if the DateTime library is where you are getting the hour from, maybe you could go look at that and THINK about it.  Or I guess you could just ask and make us tell you that there is also a minutes function.
@BulldogLowell's code was for your original specification that it should happen at 6 oclock.  Now you want it between 6 and 7, so you're going to have to do some more thinking.  His code isn't going to work if you're not looking for the point where the hour just changed.  You're going to have to think about how to write this differently to look at hours and minutes.
|| | ||| | || | ||  ~Woodstock
Delta_G
So, looking at @BulldogLowell's code where he just used 6 and 18, do either of those look like he was talking about military time?  Or just the hour part of it?  If it were military time don't you think he would have used 600 and 1800?
Again, this is going to require some thought on your part.
|| | ||| | || | ||  ~Woodstock
mbasile
should this be the format for getting the motor to turn with the time at 630pm?
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int motorPin = 9;
int lastHour = 24;
int lastMinute = 59;
void setup ()
  lcd.begin(16, 2);
  Wire.begin();
  RTC.begin();
void loop ()
  int currentMinute = now.minute();
  if (lastHour != currentHour && (currentHour == 6 || currentHour == 18)) // if the hour just changed to 6 or 18
  if (lastMinute != currentMinute && (currentMinute == 30 || currentMinute == 30)) //if the minute is 30
    feedPet = true;
    lastMinute = currentMinute;
  if (feedPet)
    turnFeeder();
    lcd.print(":");
    lcd.print(":");
    lcd.print(" ");
    lcd.print("/");
    lcd.print("/");
  if (millis() - feedTime < 3000UL) // 30 seconds
      pinState = LOW;
    pinState = HIGH;
    feedPet = false;
Delta_G
Yeah but I don't see any reason to test that currentMinute is 30 twice in the same if statement.
|| | ||| | || | ||  ~Woodstock
mbasile
just tried to implement the code with the motor.. the only thing that happened was the seconds dissapeared from the lcd and it said "time" but no motor spin
Gadgetman9
mbasile
if anyone could offer assistance as to why the motor still wont turn on and why i cant get it to turn on at 10am and at 630pm for 30 seconds at a time..... i really need some help and i have done a ton of research that still hasnt helped much
Delta_G
If you write a sketch without all the time stuff and just write the motor pin high does the motor run then?
|| | ||| | || | ||  ~Woodstock
Delta_G
If you put a print statement in turnFeeder function does it print and let you know that function is being called?
|| | ||| | || | ||  ~Woodstock
