Topic: debug (Read 1 time) previous topic - next topic
4pchen
I have the Max7219 dot led matrix with arduino uno.  I have the driver installed in my pc.  I verified and upload the example blink.  after the upload it said done upload.  but there is no action on the max 7219.  how do I make the 8*8 led run to see blinking?  thank you to help.
weedpharma
Please supply the circuit and program.
Weedpharma
4pchen
      I am a new member without experience using the Forum.  Thank you to help.  please take a look the attachment.  After upload the :Blink from example, the Tx and Rx of the ARDUINO UNO circuit were blinking as expected.  And the message was "Done upload".  but the Max 7219 led DOT matrix show no motion at all. I would like someone to help me with cost to resolve it and are appreciated very much.  i have no experience with the microcontroller at all.  This is my first time to learn the Arduino UNO.  Please help me to get started.  It is fascinated.
Peter Chen
weedpharma
There is no attachment or code.
Weedpharma
4pchen
upload the blink from arduino Example: program called Blink as follows:
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the Uno and
  Leonardo, it is attached to digital pin 13. If you're unsure what
  pin the on-board LED is connected to on your Arduino model, check
  the documentation at http://www.arduino.cc
  This example code is in the public domain.
  modified 8 May 2014
  by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
there is no error code after the Blink uploaded.
the Max 7219 Dot Led Matrix connected to Arduino uno as instructions from online as follows:
Arduino  5v to  Max 7219 vcc
Arduino Gnd to Max 7219 Gnd
Arduino 12 to Max 7219 Din
Arduino -11 to Max 7219 Clk
Arduino -10 to Max 7219 Cs
Thanks to help and appreciated!
westfw
Why do you think that the Blink example would do anything to the Max7219?
weedpharma
https://www.maximintegrated.com/en/products/power/display-power-control/MAX7219.html
Is the device data.
Your sketch only turns pin 13 on and off. There is no change to the max7219 connections.
Read the data and work from that.
Weedpharma
sidhabo
This is one example of code you need to download for testing of your Max
https://github.com/wayoda/LedControl/releases/download/1.0.6/LedControl-1.0.6.zip
I've been  Using Arduino UNO and Mega2560 so far ....
Paul__B
Right, first things first.
Go and read the instructions for using the discussion board, then go back and modify your post to mark up the code as such so anyone can examine it conveniently and accurately.
While it is pretty clear in this case what your code is about, this is a simple matter of courtesy if you expect people to help you.
4pchen
       As i said in the beginning that  i am new in the field.  i am learning to use the Forum to communicate properly with you guys.  in fact, there is an engineer, he is able get me going and i appreciate it very much.  it is wonderful in the learning.
peter
Paul__B
That's fine.
In the meantime, perhaps you could go and read the instructions, and mark up your code back in reply #4 by using the "More --> Modify" option.
4pchen
     I have to say thanks to all of you. The Maxim Engineer is polite and so helpful to get me going.  No word is enough to show my gratitude.  i am sure i will have many projects in my retiring years to come.
peter
Paul__B
