Arduino Forum
Development
Suggestions for the Arduino Project
Printing function
Print
Pages:
[1]
Topic: Printing function
(Read 2485 times)
previous topic
next topic
Datman
DATman (quando registravo con il DAT portatile :))
Faraday Member
[add]
Printing function
Nov 16, 2015, 10:40 pm
Last Edit
: Nov 17, 2015, 12:25 am by Datman
Sometimes I print (on paper) sketches. I have to copy & paste on Word, then print from there.
I'd like printing directly from the IDE, with the same colors and with line numbers if they are visible.
What do you think about it?
Hi,I'm Gianluca from Roma.I play&work with electronics since I was16(1984).
After 25yrs of maintenance on cameras&video mixers,since 2013myJob is HDTVstudios design.
Since Jan2015 IPlayWith Arduino:bit.ly/2F3LPWP
Thanks 4 a Karma if U like my answer
PaulS
Guest
Re: Printing function
#1
Nov 17, 2015, 01:00 am
Quote
I think it's a great idea. I do it all the time. Ctrl + P.
Datman
Faraday Member
[add]
#2
Nov 23, 2015, 04:13 pm
Quote from: PaulS on Nov 17, 2015, 01:00 am
It's b/w...
Colors are useful for a better reading of a long sketch.
robtillaart
Global Moderator
Brattain Member
[add]
In theory there is no difference between theory and practice, however in practice there are many...
#3
Nov 23, 2015, 06:39 pm
I use PDFwriter, that is a print to PDF driver and it captures all colours of the sketch.
If you still want paper, you could print the PDF
You can see the PDF as a sort of paperless proof print !
Rob Tillaart
Nederlandse sectie -
http://arduino.cc/forum/index.php/board,77.0.html
(Please do not PM for private consultancy)
Datman
Faraday Member
[add]
#4
Nov 23, 2015, 07:28 pm
Uhmm...
My Samsung color laser printer prints it b/w; also CutePDF Writer, set in color mode, makes a b/w pdf...
robtillaart
Global Moderator
Brattain Member
[add]
#5
Nov 23, 2015, 09:05 pm
So somewhere you have a setting (economy?) that removes all the colour settings..
Are the PDF generated also B&W?
That means it must be near the application settings. I'll have a look.
Rob Tillaart
robtillaart
Global Moderator
Brattain Member
[add]
#6
Nov 23, 2015, 09:35 pm
in the IDE
CTRL-P (Or FILE-> Print)
dialog pops up
select cute pdf writer
select 2nd tab
select color?
does this help?
Rob Tillaart
Datman
Faraday Member
[add]
#7
Nov 24, 2015, 01:49 am
No...
Color options are on.
Days ago I also tried copy&paste to word, but it was the same.
westfw
Shannon Member
[add]
Strongly opinionated, but not official!
#8
Nov 24, 2015, 10:20 am
Last Edit
: Nov 24, 2015, 10:22 am by westfw
Reason
: link to images
FWIW, I get ugly (worse than screen font) black&white text when I print to PDF on my Mac as well.
IDE:
PDF:
robtillaart
Global Moderator
Brattain Member
[add]
#9
Nov 24, 2015, 08:27 pm
@Datman
Do you have a mac linux or PC?
Rob Tillaart
Datman
Faraday Member
[add]
#10
Nov 24, 2015, 08:56 pm
PC.
Print
Pages:
[1]
Loading...
