Topic: Yet another "avrdude: verification error; content mismatch" (Read 2681 times) previous topic - next topic
djsfantasi
My Arduino Mega 2560 had been working for a while. Then tonight, I received the error in the subject when using the Arduino IDE to upload a minor change to the sketch I was working on.
I've researched this a bit, but many posts are about working with a bootloader; that is not the case here. I was uploading a sketch that had been uploaded many times before.
I thought it was the USB port on my laptop, so I tried another one. It worked once, then the error returned. I tried another sketch, but the error still appeared. I tried a simple sketch (Blink) and it uploaded successfully.
I'm at my wits end? Any ideas?
Here is the verbose upload from one attempt:
Code: [Select]
Sketch uses 27,632 bytes (10%) of program storage space. Maximum is 253,952 bytes.
Global variables use 1,474 bytes (17%) of dynamic memory, leaving 6,718 bytes for local variables. Maximum is 8,192 bytes.
C:\Program Files\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM9 -b115200 -D -Uflash:w:C:\Users\DONLUT~1\AppData\Local\Temp\build5906398027363241607.tmp/Wave_Rock_4_Test.cpp.hex:i
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 16:58:43
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Wiring
         Description     : Wiring
         Programmer Model: AVRISP
         Hardware Version: 15
         Firmware Version Master : 2.10
         Vtarget         : 0.0 V
         SCK period      : 43.5 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801
avrdude: reading input file "C:\Users\DONLUT~1\AppData\Local\Temp\build5906398027363241607.tmp/Wave_Rock_4_Test.cpp.hex"
avrdude: writing flash (27632 bytes):
Writing | ################################################## | 100% 4.61s
avrdude: 27632 bytes of flash written
avrdude: verifying flash memory against C:\Users\DONLUT~1\AppData\Local\Temp\build5906398027363241607.tmp/Wave_Rock_4_Test.cpp.hex:
avrdude: load data flash data from input file C:\Users\DONLUT~1\AppData\Local\Temp\build5906398027363241607.tmp/Wave_Rock_4_Test.cpp.hex:
avrdude: input file C:\Users\DONLUT~1\AppData\Local\Temp\build5906398027363241607.tmp/Wave_Rock_4_Test.cpp.hex contains 27632 bytes
avrdude: reading on-chip flash data:
Reading | ###avrdude: stk500v2_recv(): checksum error
#########avrdude: stk500v2_recv(): checksum error
################### | 100% 3.76s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0873
         0x01 != 0xe0
avrdude done.  Thank you.
Additional information: I can upload the same program to an Arduino UNO without error. But when uploading it to the Arduino Mega 2560, I get the content mismatch error.
Code: [Select]
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: verification error, first mismatch at byte 0x1246
         0x72 != 0xcc
djsfantasi
I tried to upgrade the IDE v1.6.6 (on 11/20) from 1.6.1, which caused another problem! All my libraries were marked as invalid.
So I punted back to 1.6.5, and it has been working fine.
