Topic: Serial.print different data types (Read 5250 times) previous topic - next topic
Rudy216
Nov 22, 2015, 11:01 pm Last Edit: Nov 22, 2015, 11:04 pm by Rudy216
 Serial.println(x, BIN);  // print as an ASCII-encoded binary
If the type for x is byte I expect the above to print out eight characters, 00110011.
But that is not what happens. Only 110011 is printed out.
If that wasn't bad enough the following floored me.
 Serial.println(~x, BIN);
produces
FFFFFFCC
Wouldn't it make sense for the output to reflect the type (size) of data that is being printed? From what I recall the same problem also exists for HEX. (and likely Octal)
Budvar10
#1
Nov 23, 2015, 08:31 am Last Edit: Nov 23, 2015, 08:32 am by Budvar10
There are overloaded function definitions for print, println in the class (see the Print.h). Compiler can choose inappropriate println version in such cases, with the unsigned long parameter in your case and the rest before byte is filled with zeros (00000033h -> ~FFFFFFCCh). The solution is to use type cast which should force the compiler to choose required version of function. Like this: Serial.println((unsigned char)(~x), BIN); .
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
Rudy216
Actually it was a signed long. When I printed it without the HEX specifier it printed as a negative number.
Thank you for your answer. It is not the answer that I had hoped to get but I really do appreciate it. And I did try it and it does what it should.
Budvar10
#3
Nov 24, 2015, 08:41 am Last Edit: Nov 24, 2015, 08:42 am by Budvar10
Of course, it's possible. It could depend on x definition, if it is signed or unsigned or something else like optimizing process and the way how the lib is written. Basically, there are 2 base versions of print() for integer - long and unsigned long, all other versions are derived println() included.
PaulS
Quote
You have unreasonable expectations, then.
If you printed 51 in decimal, you wouldn't expect 00000051, would you? Why would you expect leading 0s when printing in binary, then?
If you do expect that crap, there are ways (sprintf) to make it happen.
flyhawk001
Is it possible to implement  Serial.printf() as C language's printf() does ?
If so, we use %d for integer, %s for string, %f for float point data, etc.
We can print different data type in the same function call.
We also can print many data in the same code line.
pYro_65
We also can print many data in the same code line..
You can use my PrintEx library, you can find it in the library manager. Or here: https://github.com/Chris--A/PrintEx#printex-library-for-arduino-
It contains my own implementation which includes floating point data.
You can also use streaming in and out.
It is used to add extra functionality to any Stream or Print based library (Serial, Ethernet, SD, LCD, etc...)
