Topic: Arduino Lightsaber for/with LED string blade (Read 170225 times) previous topic - next topic
JakeSoft
BTW, I watched again your MKII Video, especally the part with the configuration.
Wow, now that I made mine, the sheer programming elegance you brought in into your saber just astonishes me...I see who is the software expert, software-wise my implementation is like a stone age club in comparison. Did you use the EEPROM to save the setting?
Thanks for the compliment, although I think I may have overdone it. The project has become so big that I moved to developing it in Eclipse because it was too hard to manage in the basic Arduino IDE. Also I think I've pushed the RAM limit of the Pro Mini with the features I'm trying to add in for the Mk. IV system. If I change something trivial, it causes what looks like memory corruption issues or outright crashes. I'm going to have to go back and do a lot of optimizing some of the not-so-elegant portions of the code before I can add anything else, or move to a chip with more RAM.
Protonerd
Hihi, cool, you know how hard it was for me to find out why even changing the most unermarkable piece of code caused a totally unexpected behaviour from the saber at a totally different location... it took weeks before it occured to me that probably the system ran out of memory for the dynamic variables. So now I know that in the current state anything I add have to be preceeded by optimizing something else. So Memory IS a great problem with the small boards and only experience is going to tell you that!
@tanakabuki: I do not want to discourage you to use other mp3 players, on the contrary by all means please try them and tell us your findings! This is how I also started and I needed to spend quite a time to go through 3 different mp3 players before I put down my coin beside the mp3-tn-16p. Now with JakeSoft's solution we have currently 2 proven mp3 modules and I would love to see more diversity here. And one more thing: the more people searching for certain features the higher the chance that a commercial solution will de developed for it.
chivotenkai
Thanks for the recommendation for the LED circuit.
I'm still waiting for the MOSFET , Arduino and sound module .
but I'm done "led string" (1 cable for V+ and five for mosfet-gnd)
Still not add the  light diffuser but I have already tried the brightness with 7.4V
It goes great
Protonerd
Wow, impressive brightness. I take you used green LED's (from the background color, because the string is so bright the camera shows only a glowing white). Greens are anyway the brightest of all LED colors.
How do you lock the LED segments in place? Do you use a stiffener? Or wrap them all in foil/shrink tube?
chivotenkai
sorry for answer late...
In the image... only the leds appear in the image.
for the creation of the string i used a similar metod of "Hampton's Hand-Crafted Lightsabers" channel.
But i change a little for make your circuit. I turn led for connect serial: if a string have 16 leds (8+8) in the middle for make the serial conection i solder de V- of the 8º Led to the V+ of the 9º Led.
Next, I Cut the V- of the 9º Led and i use that new space to solder the cable... that cable its directly going to the mosfet. Repeat the process in all strings. If you make 5 strings you have:
5 cables for V-
1 "special" for V+... I use only a cable but i cut it many times for using less space.... conecting the V+ when it have the 7.4V with the next string
kkwapnioski
 i would like to know how you achieved gapless playback with the DFPlayer mini? I am trying to create a similar build and I am having trouble with gaps when transitioning from a swing or clash back to idle hum.
Protonerd
Generally speaking the DFPlayer can transit from one sound file to another without any discernable gap. That is already a big advantage which many other MP3 players do not have!
Gapless playback you can do the 1. professional hard way or the 2. practical easy way.
1.: you have to keep track how long each track is and make sure in your code that you start the next sound just a bit earlier. Most high-end commercial saber electronics do it like that.
2.: while 1 is possible but hard to program, I choose another way. I simply extended the hum and copied the him to all other sound files. For a full sound font it takes about 5 minutes of work, well worth the effort. Since the hum will not stop aftter a few hundred ms, you have plenty of time to start a new sound.
kkwapnioski
So its definitely easier to add the hum to each sound bite, thanks for the pro tip. Next question, do you play the files from the root of the sd card, mp3 folder, or numbered folders? I think I'm getting playback gaps when trying play files from the folders, but its pretty close if not gapless when playing from the root. Did you notice anything similar? Also I'm wondering if file format makes in difference. I'm currently using wav files but now I'm curious if mp3 would make any difference in the folders.
chivotenkai
Good news.
Now I have all electronic materials.
Here is my progress
https://youtu.be/V6yZFv4wBsM
integra386
#24
Dec 12, 2015, 12:56 pm Last Edit: Dec 12, 2015, 01:02 pm by integra386
Hello everyone .... first of all congratulations for your projects.
Even I'm starting to build a lightsaber following your instructions ... but I have a little doubt.
Having never run so many LEDs together ... I would understand if it is better to place the load resistors for LEDs, or not.
The leds I bought, are the Straw Hat 5mm red (1,8-2,2v and about 30ma ... http://www.ebay.it/itm/STRAWHAT-STRAW-HAT-180gradi-100-LED-ROSSI-5000mcd-5mm-/180649038439?hash=item2a0f859267:m:m8Oli3L3bnU9JmGN3osb1VA).
Wanting to create a series-parallel LED string consists of 6 groups of 8+8 leds ... My calculations say that I need 6 resistors 18R 1w.
They are so necessary, given the low value ???
I have seen some schemes around, and often these resistors are not mentioned.
Attaching any two schemes ... do you think is correct?
Thanks so much
chivotenkai
integra386.. i dont know but... you are making a blade with 96 leds?
Protonerd can you post the code you used for acelerometer?
i make the sound work (blade on and off sound) but with the acelerometer... T.T
integra386
Protonerd
integra386, good luck!
As to the 96 leds, why not, I also have integrated 6x3x5=90 in my red blade and 6x2x8=96 in my blue blade.
As to the resistors or not: for a red blade with serial II. technic (2 LEDs in series), you need the resistors, otherwise you will have a very narrow band to control your transistors -> effects will be less spectacular. Not to mention that not all small transistors can tolerate the power dissipated over them.
Better is to use a serial III. setup, then you do not need the resistors. 2.2V*3=6.6V, you only need to dissipate max. 8.2V-6.6V=1.6V over the MOSFET. If you insist on the serial II., then you need the resistors.
BTW, looking at your schematics, please do not forget the pull-down resistors from transistor gate to GND, otherwise you will have floating gate and you cannot control switch on/off (all LEDs will always be somehow in a random on state).
integra386
Protonerd thanks for the reply .... then I will make from 96 to 90 LED ... 6 x ( 3 x 5 ) .
I updated again the scheme ... now should be correct .
Protonerd
Thumbs up!
How do you intend to interlink the LEDs?
