Topic: Project 9 extra challenge (Read 5214 times) previous topic - next topic
arduino-newbie
I get the concept of the extra challenge question on project 9.  Activating the transistor using a PWM pin, and I have done that using the:
analogWrite(motorPin, 255); or 90 or 0 etc...
but how would I run that using a potentiometer through the Analog input? I would need to calculate the Analog input 0 - 1023(?) and then correlate that with a PWM 0 - 255,
I'm just a bit uncertain as to what to type in to program that.
Does this make any sense?
Thanks
The challenge is:
Try hooking up a potentiometer to an analog input and use that to PWM the pin that controls the transistor.
my current sketch code is:
const int switchPin = 2;
const int motorPin = 9;
int switchState = 0;
pinMode(motorPin, OUTPUT);
pinMode(switchPin, INPUT);
switchState = digitalRead(switchPin);
if(switchState == HIGH) {
  analogWrite(motorPin, 90);
else{digitalWrite(motorPin, LOW);}
dannable
Have you done an analog read exercise?
https://www.arduino.cc/en/Tutorial/AnalogReadSerial
The potentiometer can return a value of 0 - 1023. The speed of the motor on PWM takes a value of 0 - 255, ie a quarter of the value of the analog read value.
In future please post any code between code tags. If you don't know how to do this then read the topic entitled 'How to use this forum'.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
arduino-newbie
Thanks for the reply, I just finished the analog exercise and I have tweaked my code a bit, I'm getting mixed results.
I did read the 'How to use this forum' post, unfortunately it was after I had posted the code.  I will be sure to use the proper protocol going forward.
I now am dividing the A0 by 4 and having the analogRead act on that number.  What is happening is that I'm only seeing vary small variances in the Serial window, on the upper end of the pot it reads 255, on the other end it reads 251.  I may be doing something wrong.
Code: [Select]
int sensorValue = analogRead(A0/4);
Serial.println(sensorValue);
delay(1);
  analogWrite(motorPin, sensorValue);
dannable
Close! You are reading the value of (pin A0 divided by four), rather than (pin A0) divided by four!
KLHL
#4
Dec 14, 2015, 03:46 pm Last Edit: Dec 14, 2015, 05:09 pm by KLHL
One way to do it, propably a better way available from someone else.
I added an extra transistor for the potentiometer and a capacitor 10µF that takes away the remaining current that's left in the circuit so the engine stops faster and smoother.
KLHL
#5
Dec 14, 2015, 03:56 pm Last Edit: Dec 14, 2015, 05:09 pm by KLHL
amason2
#6
Jan 19, 2019, 06:40 pm Last Edit: Jan 19, 2019, 06:50 pm by amason2
Tinkercad link
This works perfect.
Code: [Select]
const int potPin = A0;
int motorSpeed = 0;
int potVal = 0;
  potVal = analogRead(potPin);
  motorSpeed = map(potVal, 0, 1023, 0, 255);
  analogWrite (motorPin, motorSpeed);
