Topic: [Mechanics] Why delta robots have 2 arms per one motor arm (Read 462 times) previous topic - next topic
tonko_lonko
Hello,
I am wondering why all delta robots have 2 arms per one motor arm.?
I.e
Why we have 2 arms for every motor arm?
I think that it should work with one arm and the down effector will still be parallel.
All designs available in internet use two arms but the only reason I can see is if their universal joins are
half spheres and they need a spring between them to hold the joins.
if we use regular ball joints / end rods / it should work with one arm per motor right?
Thanks
Anton
Robin2
Maybe it is easier to get the required stiffness and freedom from rotational stresses with a paired arm.
Try it and see, and report back.
..R
Two or three hours spent thinking and reading documentation solves most programming problems.
MarkT
Because you need at least 6 pivoted(*) support points to define the position of the head, use less
and the structure is floppy - its position is not completely constrained as an object has 6 degrees of
freedom and each link can only constrain one degree of freedom.
(*) we are talking about freely pivoted at both ends - each link only constrains the distance
between its ends.
Compare to a Stewart platform.
