[quote author=James C4S date=1449336075 link=msg=2508828]
What kit? What book?[/quote]
not sure...
If you aren't able to upload programs what have you tested with the Serial Monitor? That you can open it? Which does show that the serial monitor can open the serial port it's been given.[/quote]
what i did was i connected the rx and tx ports so any info sent to the board would loop back to the computer, then i sent some info through.
Then the download is failing.
Turn on Verbose Output in the preferences. Copy/paste the output into a post here. (Ideally using code tags.)[/quote]
IDK what code tags are and the output was too long so i put what i think you might need, but i did the verbose upload; here's the output (between the curly bracers)
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Took out some here
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82] [20]
avrdude: Send: A [41] . [98] [20]
Hardware Version: 3
Firmware Version: 4.4
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.01s
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00] [20]
avrdude: Recv: . [00]
avrdude: reading input file "C:\Users\user\AppData\Local\Temp\build8021311611748217387.tmp\LiquidCrystalBall.cpp.hex"
avrdude: writing flash (3276 bytes):
Writing | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] b [62] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [99] . [03] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [00] . [00] . [00] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] . [00] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [00] . [00] . [00] . [00] [20]
I cut a bit out here because it was WAY too long
##avrdude: Send: U [55] @ [40] . [06] [20]
avrdude: Send: t [74] . [00] L [4c] F [46] [20]
avrdude: Recv: a [61] g [67] a [61] i [69] n [6e] . [00] U [55] m [6d] , [2c] [20] w [77] h [68] a [61] t [74] ? [3f] . [00] W [57] a [61] t [74] [20] u [75] [20] s [73] a [61] y [79] ? [3f] . [00] A [41] s [73] k [6b] [20] t [74] h [68] e [65] [20] L [4c] i [69] q [71] u [75] i [69] d [64] . [00] C [43] r [72] y [79] s [73] t [74] a [61] l [6c] [20] B [42] a [61] l [6c] l [6c] ! [21] . [00] . [01] . [00] . [00] . [00] . [00] . [00] . [00] . [00] _ [5f] . [02] . [1e] . [05] . [00] . [00] @ [40] . [00] . [14] . [00] T [54] . [00]
| 100% 0.61s
avrdude: verifying ...
avrdude: 3276 bytes of flash verified
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
That isn't a "mode." That is for using a hardware programmer. If you do not have a ISP programmer attached, upload using programmer does nothing.[/quote]
i know, but i needed some sort of error to find the problem
What do you mean by "devices?" You've tried multiple Arduino boards and get the same error? (What error? You said uploads complete fine.)[/quote]
by "devices" i mean different computers that i tried to upload code to the board from. by the error/uploads fine, i mean that with programmer (for more info on the problem), there is the error message shown above as the only indicator of a problem, but without programmer, there is no error message shown, and it looks like the upload is fine until you try to run the code on the board.
thanks for helping!
DiyHacker1
