Topic: ethernet locks up in Ethernet.begin (Read 953 times) previous topic - next topic
rekinchin
Hi Folks,
I have never used arduino before, but it seems everything is locked away so if a function like this fails I have no idea where to start debugging.
I am a hardware designer (and experienced firmware engineer) and have taken the Ethernet design from the schematics and incorporated it into my clients design.
I have 1 PCB functioning correctly but my second locks up in the Ethernet.begin function. I assumed the compiler used the library sources, but it seems that it doesn't.
My signals all look correct and I can get ping responses from the W5100. See below: (unreachable when not plugged in, packet received when it is)
Pinging 192.168.0.14 with 32 bytes of data:
Reply from 192.168.0.6: Destination host unreachable.
Reply from 192.168.0.14: bytes=32 time=1003ms TTL=128
Ping statistics for 192.168.0.14:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1003ms, Maximum = 1003ms, Average = 1003ms
I have managed to get a bit further.
functions:
  W5100.init()
  SPI.beginTransaction(SPI_ETHERNET_SETTINGS)
  W5100.setMACAddress(mac)
  W5100.setIPAddress(ip)
  SPI.endTransaction()
all return, but _dhcp->beginWithDHCP() locks up, however I am not sure if I had declared _dhcp correctly when copy pasting code.
Any ideas how I debug this please.
Robert
SurferTim
Posting your code might help. Do you have a SD card or any other SPI device connected to your device?
rekinchin
#2
Dec 08, 2015, 05:07 pm Last Edit: Dec 08, 2015, 05:16 pm by rekinchin
The code is just the DHCPAddressPrinter example. I did try and breakdown some of the .begin function using this
Code: [Select]
#include <SPI.h>
#include <IPAddress.h>
#include <Dhcp.h>
#include "C:/Program Files (x86)/Arduino/libraries/Ethernet/src/utility/w5100.h"
 * Copyright (c) 2010 by Arduino LLC. All rights reserved.
 * This file is free software; you can redistribute it and/or modify
 * it under the terms of either the GNU General Public License version 2
 * or the GNU Lesser General Public License version 2.1, both as
 * published by the Free Software Foundation.
#include <stdio.h>
#include <string.h>
// W5100 controller instance
//W5100Class W5100;
#define TX_RX_MAX_BUF_SIZE 2048
#define TX_BUF 0x1100
#define RX_BUF (TX_BUF + TX_RX_MAX_BUF_SIZE)
#define TXBUF_BASE 0x4000
#define RXBUF_BASE 0x6000
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
byte ip[] = {
  0, 0, 0, 0, 0, 0
DhcpClass *_dhcp;
  static DhcpClass s_dhcp;
  _dhcp = &s_dhcp;
  while (!Serial) {
  // start the Ethernet connection:
  Serial.println("1");
    W5100.init();
  Serial.println("2");
  SPI.beginTransaction(SPI_ETHERNET_SETTINGS);
  Serial.println("3");
  W5100.setMACAddress(mac);
  Serial.println("4");
  W5100.setIPAddress(ip);
  SPI.endTransaction();
  Serial.println("5");
  int ret = _dhcp->beginWithDHCP(mac, 10, 40);
  Serial.println("6");
That hangs on int ret = _dhcp->beginWithDHCP(mac, 10, 40); after printing "5"
No additional hardware on the SPI port
Robert
PaulS
Code: [Select]
DhcpClass *_dhcp;
  _dhcp = &s_dhcp;
I don't understand the purpose of this. Why define a pointer to a static instance?
rekinchin
Ask arduino!!! that's the Ethernet.cpp library Ethernet.begin function
Code: [Select]
int EthernetClass::begin(uint8_t *mac_address, unsigned long timeout, unsigned long responseTimeout)
  stat  ic DhcpClass s_dhcp;
  _dhcp = &s_dhcp;
  // Initialise the basic info
That I copied to see what is happening
rekinchin
Update:
I have a further PCB functioning now, so the problem is certainly hardware (2 boards OK 1 fails). Also a working PCB will go through my test code and display all 6 messages. SO, my question becomes what can cause it to hang in _dhcp->beginWithDHCP()  (even with timeout?)
Robert
rekinchin
I'm closing this post.. I have found that working copies of the libraries sit in a documents/arduino folder from that I have identified the problem. I shall post that as another posting.
Thanks for help
Robert
