Topic: buzzing sound from TMRpcm (Read 1 time) previous topic - next topic
elsis310
Hello everyone :)
I'm using a piezo, sd card, Arduino Uno and wires to play a song with the TMRpcm library.
The sd card works ok and the arduino finds the correct songs.
I adjusted the file to be in WAV format, 8 bit and all the other settings.
When I use the tmrpcm.play("file.wav"); function, the piezo plays buzzing sound.
I used instead of the piezo another speaker, and the problem is still there...
Help me please !!
What should I do?
Grumpy_Mike
That will happen if your sampling frequency is too low what are you using?
elsis310
#2
Dec 10, 2015, 04:00 pm Last Edit: Dec 10, 2015, 04:27 pm by elsis310
I tried 8Khz, 16 Khz and 22Khz using Itunes converter.
Should I try all the rest?
Grumpy_Mike
Quote
No I wouldn't bother.
Have you tried using a speaker or headphones in place of the piezo? These are not really speakers and have a sharp resonance in their response and that could be causing you the excess noise.
prakhar123
hi you could set the song above 32hz and then try it should work
Grumpy_Mike
Quote
No it will sound dreadful. Now 32KHz might be a place to start.
And don't resurrect a three year old post if you have nothing sensible to say.
MarkT
"KHz"?  Did you mean "kHz" or "KiHz" ?  :)
