Topic: sdcard webserver is too slow connection (Read 1 time) previous topic - next topic
dannybear
I made a simple sdcard webserver, it worked good. Then i designed a web htm include many words, and Hyperlinks, it worked but the connection is so slow. What's the problem from? help me pls.
this is my code, i learn it from here
Quote
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,21);
IPAddress dns1(192,168,0,1);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
EthernetServer server(80);
File webFile;
    Ethernet.begin(mac, ip, dns1, gateway, subnet);
    server.begin();
    digitalWrite(10, HIGH);
    if (!SD.begin(4)) {
        return;
    int BUFSIZ = 255;
    int index = 0;
    char clientline[BUFSIZ];
    if (client) {
        boolean currentLineIsBlank = true;
        index = 0;
        while (client.connected()) {
            if (client.available()) {
                char c = client.read();
                if (c != '\n' && c != '\r') {
                  clientline[index] = c;
                  index++;
                  if (index >= BUFSIZ)
                    index = BUFSIZ -1;
                  continue;
                clientline[index] = 0;
                char* filename = processFile(clientline);
                Serial.print("Requested: ");
                Serial.println(filename);
                /* Setup AJAX Requests Here:
                 * These are just direct output values that are requested
                 * with AJAX.
                if (strstr(clientline, "GET /?data=val1") != 0) {
                  code200(client);
                  client.println(1337);
                if (SD.exists(filename)) {
                   code200(client);
                   webFile = SD.open(filename);
                   if (webFile) {
                       while(webFile.available()) {
                           client.write(webFile.read());
                       webFile.close();
                    if (strlen(filename) < 2) {
                      webFile = SD.open("index.htm");
                       if (webFile) {
                           webFile.close();
                      client.println("HTTP/1.1 404 Not Found");
                      client.println("Content-Type: text/html");
                      client.println("Connection: close");
                      client.println();
                      client.println("<html><head><title>404 - Not Found</title></head><body><h1>404 - Not Found</h1></body></html>");
        delay(1);
        client.stop();
void code200(EthernetClient client) {
    client.println();
char* processFile(char clientline[255]) {
   char *filename;
   filename = clientline + 5;
  (strstr(clientline, " HTTP"))[0] = 0;
  return filename;
the website look like.
SurferTim
This will cause your code to run slow. It sends one byte per packet.
Code: [Select]
This is much faster. tBuf is a 64 character array.
Code: [Select]
  while(myFile.available()) {
    clientCount = myFile.read(tBuf,64);
    client.write((byte*)tBuf,clientCount);
Here is my server code.
http://playground.arduino.cc/Code/WebServerST
