Topic: MCUFRIEND_kbv Library for Uno 2.4, 2.8, 3.5, 3.6, 3.95 inch mcufriend Shields (Read 325611 times) previous topic - next topic
MosheB
Hi to all,
I got the next SPI TFT ILI9341
https://www.ebay.com/itm/2-8-TFT-LCD-Display-Touch-Panel-SPI-Serial-240-320-ILI9341-5V-3-3V-STM32/201950756171?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I tried running a examples from Adafruit_ILI9341 library, and I get a white screen.
Is there a recommendation for another library? And what connections?
Thanks a lot.
MosheB
david_prentice
The MCUFRIEND_kbv library is for Mcufriend Uno shields.
It does NOT support the SPI TFT ILI9341.    But there are plenty of libraries that do.  e.g. Adafruit_ILI9341, TFT_ILI9341, ILI9341_due, ILI9341_PDQ, ...
Note that your screen requires 3.3V logic.    e.g. Zero, Due, Teensy3.x, ...
If you want to use a 5V Uno or Mega,  you MUST use level shifters.
David.
MosheB
First of all thank you,
As I wrote, I tried the sample from the library Adafruit_ILI9341 and I get a white screen.
I'll try the rest you recommend.
Thanks.
david_prentice
Adafruit examples deliberately omit the RST argument in the constructor.
Presumably to make their screens work and your screen fail.
Add the optional RST argument for your Red screen.   Google "ILI9431 SPI Adafruit".    Ask on relevant threads.
David.
MosheB
Thanks for the offer, but I did not really understand what to do with RST.
Can you please explain?
Thanks.
paulofeju
Hello David, I modified the example "no_showBMP_Uno" with the purpose of simplifying it to show only one BMP (16 or 24bit) and build a specialized function after. It worked well but I think it could simplify more.
Could you please review the attached skecth for me?
- All my modifications are marked with "@"   ( "//@"    "*/@"    or   "@/*")
- Image files on SD --> 16 or 24bitBMP.
- TFT Shield              --> Mcufriend TFT 2.8 BLUE (HX8347D, ID 0x4747).
Thanks a lot my friend!!!!!
david_prentice
Some of your edits are unwise.   e.g. not testing for TFT ID or valid BMP ID.
I suggest that you always press ctl-T to format your code nicely.   It makes all the difference to readability.
Personally,  I would delete all the extraneous lines.   Even with the ctl-T formatted sketch,   it is still clearer without the unused lines.
Did you try my example?
David.
paulofeju
Yes, I tried your example and replied this on #1979:
"Fantastic!!! Thats just the solution for what I've been trying to do in the last days! It worked well, but slower then when loading bmp with showBMP. Now I'm trying to build a similar sketch for bmp files, but no success yet. Next step will be for jpeg files.
Many Thanks David!!!"
I learn more and more each time I read your posts. :)
Here's the last and cleanest version of the adapted "show_BMP" that I could build:
Code: [Select]
// MCUFRIEND UNO shields have microSD on pins 10, 11, 12, 13
// The official <SD.h> library only works on the hardware SPI pins
// e.g. 11, 12, 13 on a Uno
// e.g. 50, 51, 52 on a Mega2560
// e.g. 74, 75, 76 on a Due
// if you are not using a UNO,  you must use Software SPI:
// install v1.0.1 of the <SdFat.h> library with the Arduino Library Manager.
// edit the src/SdFatConfig.h file to #define ENABLE_SOFTWARE_SPI_CLASS 1
// copy all your BMP files to the root directory on the microSD with your PC
// (or another directory)
//  * Adapted from "Show_BMP_not_Uno.ino" (One of the examples from "MCUFRIEND_kbv Library
//   for Uno 2.4, 2.8, 3.5, 3.6, 3.95 inch mcufriend Shields" by PRENTICE, DAVID).
//   https://github.com/prenticedavid/MCUFRIEND_kbv
//   PURPOSE: A simpler possible function to Load/Show only one BMP at a time from SD card.
//   RESTRICTED CONDITIONS:     - Image Files: 16 or 24bitBMP (w<=320, h<=240).
//                              - Uno tft Shield: mcufriend 2.8" Blue (HX8347D; ID=0x4747).
//                              - Shield plugged on Mega 2560 R3.
//   Still under construction.
//   VERY GRATEFUL TO DAVID FOR THE VALUABLE LESSONS AND KINDLY "PATIENCE" WITH A NEWBIE.
#include <SPI.h>             // f.k. for Arduino-1.5.2
#include <SdFat.h>           // Use the SdFat library
#include <Adafruit_GFX.h>    // Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
SdFatSoftSpi<12, 11, 13> SD; //Bit-Bang on the Shield pins
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL      20
{ tft.begin(0x4747);
  SD.begin(10);
  tft.setRotation(3);
void loop() { //FOR TESTS
  char *imagefile = "/test/MOTO_CORRIDA_16bit.bmp"; //var imagefile MUST BE ASSIGNED ON THE MAIN SKECTH
  tft.fillScreen(0);
  showBMP(imagefile, 0, 0);
  imagefile = "tiger_24bit.bmp"; //var imagefile MUST BE ASSIGNED ON THE MAIN SKECTH
  tft.fillScreen(0);
uint16_t read16(File& f) {
  uint16_t result;         // read little-endian
  f.read(&result, sizeof(result));
  return result;
uint32_t read32(File& f) {
  uint32_t result;
  return result;
uint8_t showBMP(char *imagefile, int x, int y)
  File bmpFile;
  int bmpWidth, bmpHeight;    // W+H in pixels
  uint8_t bmpDepth;           // Bit depth (currently must be 24, 16, 8, 4, 1)
  uint32_t bmpImageoffset;    // Start of image data in file
  uint32_t rowSize;           // Not always = bmpWidth; may have padding
  uint8_t sdbuffer[3 * BUFFPIXEL];    // pixel in buffer (R+G+B per pixel)
  uint16_t lcdbuffer[1 + BUFFPIXEL];
  uint8_t bitmask, bitshift;
  boolean flip = true;        // BMP is stored bottom-to-top
  int w, h, row, col, lcdbufsiz = 1 + BUFFPIXEL, buffidx;
  uint32_t pos;               // seek position
  boolean is565 = false;      //
  uint8_t ret;
  bmpFile = SD.open(imagefile);      // Parse BMP header
  (void) read16(bmpFile);
  (void) read32(bmpFile);     // Read & ignore file size
  (void) read32(bmpFile);     // Read & ignore creator bytes
  bmpImageoffset = read32(bmpFile);       // Start of image data
  (void) read32(bmpFile);     // Read & ignore DIB header size
  bmpWidth = read32(bmpFile);
  bmpHeight = read32(bmpFile);
  (void)read16(bmpFile);
  bmpDepth = read16(bmpFile); // bits per pixel
  pos = read32(bmpFile);      // format
  bool first = true;
  is565 = (pos == 3);               // ?already in 16-bit format
  // BMP rows are padded (if needed) to 4-byte boundary
  rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
  if (bmpHeight < 0) {              // If negative, image is in top-down order.
    bmpHeight = -bmpHeight;
    flip = false;
  w = bmpWidth;
  h = bmpHeight;
  // Set TFT address window to clipped image bounds
  tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
  for (row = 0; row < h; row++) { // For each scanline...
    // Seek to start of scan line.  It might seem labor-
    // intensive to be doing this on every line, but this
    // method covers a lot of gritty details like cropping
    // and scanline padding.  Also, the seek only takes
    // place if the file position actually needs to change
    // (avoids a lot of cluster math in SD library).
    uint8_t r, g, b, *sdptr;
    int lcdidx, lcdleft;
    if (flip)   // Bitmap is stored bottom-to-top order (normal BMP)
      pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
    else        // Bitmap is stored top-to-bottom
      pos = bmpImageoffset + row * rowSize;
    if (bmpFile.position() != pos) { // Need seek?
      bmpFile.seek(pos);
      buffidx = sizeof(sdbuffer); // Force buffer reload
    for (col = 0; col < w; ) {  //pixels in row
      lcdleft = w - col;
      if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
      for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) { // buffer at a time
        uint16_t color;
        // Time to read more pixel data?
        if (buffidx >= sizeof(sdbuffer)) { // Indeed
          bmpFile.read(sdbuffer, sizeof(sdbuffer));
          buffidx = 0; // Set index to beginning
          r = 0;
        switch (bmpDepth) {          // Convert pixel from BMP to TFT format
          case 24:
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            color = tft.color565(r, g, b);
          case 16:
            if (is565)
              color = (r << 8) | (b);
              color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
        lcdbuffer[lcdidx] = color;
      tft.pushColors(lcdbuffer, lcdidx, first);
      first = false;
      col += lcdidx;
    }           // end cols
  }               // end rows
  tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1); //restore full screen
  bmpFile.close();
Klaudiusz_W
How to load Bitmap with library utftglue?
david_prentice
WHY?
What kind of Bitmap?
I kludge this UTFT method in UTFTGLUE:
Code: [Select]
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int scale=1);
but I make no attempt to draw a bitmap at an angle i.e. this UTFT method:
Code: [Select]
void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int deg, int rox, int roy);
I provide example showBMP sketches for rendering BMP files from SD card.
The Adafruit_GFX class has several methods:
Code: [Select]
    drawBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
      int16_t w, int16_t h, uint16_t color),
      int16_t w, int16_t h, uint16_t color, uint16_t bg),
    drawBitmap(int16_t x, int16_t y, uint8_t *bitmap,
    drawXBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
    drawGrayscaleBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
      int16_t w, int16_t h),
    drawGrayscaleBitmap(int16_t x, int16_t y, uint8_t *bitmap,
      const uint8_t bitmap[], const uint8_t mask[],
      uint8_t *bitmap, uint8_t *mask, int16_t w, int16_t h),
    drawRGBBitmap(int16_t x, int16_t y, const uint16_t bitmap[],
    drawRGBBitmap(int16_t x, int16_t y, uint16_t *bitmap,
      const uint16_t bitmap[], const uint8_t mask[],
      uint16_t *bitmap, uint8_t *mask, int16_t w, int16_t h),
The GFX drawBitmap() methods are monochrome.   The GFX methods end up by drawing one pixel at a time.   It is faster to use TFT hardware.
David.
Klaudiusz_W
Thanks!
I'd like to to draw a bitmap from sd card.
showBMP_kbv_as7 works fine, but this sketch work on MCUFRIEND_kbv tft - not utftglue.
david_prentice
Why do you want UTFTGLUE?
UTFTGLUE only sends UTFT methods to the underlying MCUFRIEND_kbv object.
What do you want to do with UTFT style methods that can not be done with Adafruit_GFX methods?
In fact you will find that a UTFTGLUE object is able to perform both UTFT and GFX methods.
I strongly advise you to stick to GFX.   Only use UTFTGLUE for a legacy UTFT program.   Never try to mix both styles because it gets confusing.
David.
Klaudiusz_W
So I shoud use MCUFRIEND_kbv? How to, for example change text font?
