Topic: My Code Doesn't Work (Read 601 times) previous topic - next topic
-ChopinCJ-
Hello,
I'm wondering why this code snippet wasn't working. (It's probably something obvious which I didn't notice.  That happens all the time! :) )
String var = "asdfqwerty";
  var = Serial.read;
  Serial.println("What is your name?");
  while (var == "asdfqwerty") {
    delay(50);
Thanks,
         -ChopinCJ-
aarg
What is is supposed to do?
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
jremington
#2
Dec 26, 2015, 05:01 pm Last Edit: Dec 26, 2015, 05:02 pm by jremington
That code makes no sense and won't even compile, which might explain why it doesn't work.
Please read and follow the instructions in "How to use this forum".
jurs
  var = Serial.read;
I think this forum already contains 1000 threads discussing why you should NOT use the "String" class type in your program as well as another 1000 threads discussing "Serial input basics" and leading with a link to that thread:
https://forum.arduino.cc/index.php?topic=288234.0
Do you possibly think we need also 1000 threads discussing the combination of "String" and "Serial input basics"?
aarg
robtillaart
#5
Dec 26, 2015, 07:21 pm Last Edit: Dec 26, 2015, 07:21 pm by robtillaart
Try this, not perfect but might do a bit like you want
Code: (not tested) [Select]
String var = "";
  if (Serial.available() > 0) var += (char)Serial.read();
  if (var == "abc")
    Serial.println("right");
    var = "";
  if (var.length() > 3)
    var = "";
Christmas Gift :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
zoomkat
Quote
Not sure what your code is supposed to do, but below is some simple serial test code that includes character capture and comparison.
Code: [Select]
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
      Serial.println("LED ON");
    if (readString == "off")
      digitalWrite(ledPin, LOW);
      Serial.println("LED OFF");
    readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
