Topic: Arduino the Object Oriented way (Read 52732 times) previous topic - next topic
PaulMurrayCbr
Some changes made. I have a couple of annoying writing ticks: overuse of 'of course', saying "note that X" rather than simply saying "X". And I included a link to a relevant wikipedia page.
msssltd
Genuinely don't know what you had in mind when you wrote that.
"Careful with that axe, Eugene(!)" Is a lengthy instrumental number by Pink Floyd.  The track was later reworked and re-named, "Come in number 51. Your time is up!"  Both titles refer to self indulgence.
What I had in mind was the irony, of attributing prejudices to stereotypes.
Robin2
#32
Jan 03, 2016, 01:49 pm Last Edit: Jan 03, 2016, 01:51 pm by Robin2
Apologies for my musical ignorance. I may recognize it if I heard it - but I am very poor at titles.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
PaulMurrayCbr
I have a question though on constructor vs setup() use. Could you please give me some more details/examples on what can be put inside the constructor of a class and what should be part of a setup() method?
setup() for anything that calls methods from the arduino liobrary - anything to do with hardware initalisation. pinMode() is the most common thing.
constuctor for stuff that is "pure" C++. Especially for setting const variables.
The point to remember is that the Arduino environment does quite a bit of work before setup() gets called. I don't know what, exactly, but you can't rely on the hardware state being reasonable until then.
Constructors get called ... actually, I don't know when constructors get called. It may even be the case that thinks like assignments to const variables are pulled out by the compiler and baked into the binary image - they never really get executed at all.
I mean … maybe I'm wrong. Maybe it would all be perfectly ok to put things in constructors. But then again, maybe not.
For example, it's common for things like the LCD object provided by a library to have a constructor to assign the pins, but a separate initialize() method to be called in setup().
Coding Badly
Early.  Well before anything Arduino has run.
Correct design.
westfw
#36
Oct 08, 2019, 08:37 am Last Edit: Oct 08, 2019, 09:17 am by westfw
In the compiler-added startup code, after "initialized data" is copied from flash into RAM and uninitialized data is cleared, and before main() is called.
PaulMurrayCbr
IIRC, C++ destructor semantics are difficult to navigate when you have multiple virtual inheritance and things like that. The best practice seems to be not to write things that rely on clever destructor behaviour.
charlesgoodwin
Liked your take on Arduino OO design with setup and loop as standard methods.
I'll bear it in mind for future coding
In my day when defining classes, I seem to recall coding let and set functions for object properties.
How would you implement read only object properties or integrated validation for setting an object property?
