Topic: error in using overloaded constructor (Read 2461 times) previous topic - next topic
epokh
I'm a new arduino developer and I'm implementing my neural net libraries for the pololu robot.
I have a weird error when trying to use a class with an overloaded constructor.
Basically the .h looks like this:
Code: [Select]
class NeuronBP
 public:
   // ====================  LIFECYCLE   =========================================
   /*! Constructor f,q */
   NeuronBP(double f=DEF_F, double q=DEF_Q);
   /*! Constructor void*/
   NeuronBP();
and the c++ code looks like:
Code: [Select]
NeuronBP::NeuronBP(double f, double q)
 reset();
 normalize_ = true;
 burst_ = false;
 setFQ(f,q);
/** Constructor that sets frequency and quality.
*      @param  f double - The frequency.
*      @param  q double - The quality.
NeuronBP::NeuronBP()
 NeuronBP(NeuronBP::DEF_F,NeuronBP::DEF_Q);
The library is succesfully compiled and I can use it in this way:
Code: [Select]
void loop()                     // run over and over again
 NeuronBP nrnbp(0.2,0.5);
 for(double k=1.0;k<10.0;k=k+10.0)
  nrnbp.calculate(k);
but when I try to use:
Code: [Select]
 NeuronBP nrnbp();
  nrnbp.calculate(k);
The compiler says:
Quote
In function 'void loop()':
error: request for member 'calculate' in 'nrnbp', which is of non-class type 'NeuronBP ()()
it seems it considers two classes within the 2 different constructors.
Is it because i can't use overloading in classes?
mellis
Change:
NeuronBP nrnbp();
to:
NeuronBP nrnbp;
Putting the () after it actually makes nrnbp a pointer to a function that returns a NeuronBP, rather than just a variable of type NeuronBP.
mellis
Also, you might have problems because it's ambiguous to have both a default constructor and a constructor in which all the parameters are optional.  You should be able to just delete the default constructor (or make one of the parameters non-optional in the other constructor).
epokh
It's true: mine was a very stupid mistake!
The corrected version now looks like:
NeuronBP.h
Code: [Select]
class NeuronBP
 private:
   static const double  DEF_F = 0.1;
   static const double  DEF_Q = 0.51;
 public:
and is working and compiling now I *only* have to test it  ;D
