Topic: Unable to upload -- >ERROR: Timed out waiting for Arduino 101. (Read 16116 times) previous topic - next topic
Chinhooi8
I am using Windows 10 and am using the Arduino Editor on the Web and have installed the Windows Driver , but getting the time out message.
Have tried with 2 lap tops and same issue.
Getting frustrated... How do I downgrade it?
ballscrewbob
Chinhooi8
I think you mean UPGRADE it.
There was an update for the 101that you should probably install.
Another thing is to AVOID USB 3.0 ports where possible with Arduino products unless you are 100% sure about the compatibility.
The desktop version of the IDE is your only proper method for the firmware upgrade and after that it should be fine with the web editor.
The process is explained HERE
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
WestLaBill
Was having the same problem and this post solved it for me with a 3 second wait.
"I solved it so: Click on the "Upload" button in IDE, wait 3-5 seconds and press and hold the button "Master Reset" on your Arduino 101. After that my Arduino worked fine."
Thanks Mates!
