Topic: Program for MLX 90614, DT11 and a motor (Read 427 times) previous topic - next topic
abhisheksingh9
Respected all my seniors here
i am totally new to the Arduino and for the college project i am supposed to program an Arduino UNO for the Sensors MLX 90614 , DT 11 as input and running a motor as output.
the MLX 90614 is a IR sensor.
The DT 11 is a humidity sensor and Motor is a 12 V dc motor.
the program should be that the sensors(both)  should take a reading after 20 seconds and if the temperature reaches beyond 70 degree celsius along with the humidity above 60% the motor should be actuated.
and again de activated once the temperature falls below 70 degree celsius.
also if humidity falls below 60% then temperature sensor shud remain off
please suggest a programming or how to do it for the above conditions.
abhisheksingh9
also i am using l298n motor driver
i will pay 50% after completion of code and 50% after succesful running of my device
PaulS
Quote
If you can read the temperature and can read the humidity, and can make the motor move, turning the motor on and off under appropriate circumstances is trivial.
Can you read the temperature?
Can you read the humidity?
Can you make the motor start and stop?
