Topic: Wifi Shield Not Present Problem (Read 1 time) previous topic - next topic
Travisbklein
Jan 12, 2016, 06:15 am Last Edit: Jan 12, 2016, 06:30 am by Travisbklein
Hey guys, after searching for about 2 hours I am still getting a "wifi shield not present" in my serial monitor.
I have the Arduino UNO R3 Board Module With DIP ATmega328P(Blue)
I bought the CC3000 WiFi Shield for Arduino UNO R3 MEGA2560 SimpleLink smartConfig with SD
I've read many posts about a jumper needing to be removed, but I do not see any jumpers.
Uploading of sketches works great with the wifi shield connected
I'm using Arduino 1.6.5 and when I try to upload the "ConnectwithWPA" example sketch I keep getting wifi shield not present.
thanks for the help.
Travis
Edit: here is an image of the unit,  you can see the green LED status light lit.
https://www.dropbox.com/s/u48bx2ch0i89yt1/20160112_001837.jpg?dl=0
PaulS
Quote
From what library? If you are using the example from the WiFi folder in the core libraries folder, that is for THE Arduino WiFi shield, which is NOT what you have. So, it's no wonder the code can't find THE Arduino WiFi shield.
Travisbklein
wow I'm such a newbie.
I am going to use this guide here to install it:
https://learn.sparkfun.com/tutorials/cc3000-hookup-guide
thanks for the help!
Thomas499
before you waste to much time. when you hook up the wifi shield run the server built in example. Once you pull up the server example code using a computer not connected to the arduino, keep the arduino hooked up for 3 days. In three days see if the arduino will respond.
The results I found are the reasons the wifi shield was discontinued. Using the wifi shield will cause the arduino to become unresponsive "freeze" within 2 weeks. Usually it takes 12-20 minutes but I found that depending on your code the time will vary. Even if you only run the wifi code once and close the server, it will not go 3 days without becoming unresponsive.
I was told the problem is in the firmware of the wifi shield.
Using the shield as a client only allows the shield to run without freezing the arduino for a little longer, but it the results will be the same within a day or two longer than if used as a server.
Hope this saves you some time. I'm not sure if the yun has the same problem.
svenkat86
Hi Travis,
I recently bought a CC3000 WiFi Shield for Arduino UNO R3 MEGA2560 SimpleLink smartConfig with SD board from ebay and i am having the same problem. Did u resolve the issue and did your wifi shield go past the shield not present error. Please share your updates on how you fixed it.
Thanks.
