Hello everyone,
I have a 2 digit 7 segment display that cycles from 22, 44, 66, 88. However I would like the numbers to cycle from 22, 24, 26, 28, 42, 44.....etc. How would I approach this/ how can I get two different numbers to display at the same time?
Showing number 0-9 on a Common Anode 7-segment LED display
Displays the numbers 0-9 on the display, with one second in-between.
A
F | | B
| G |
E | | C
D
//Numbers
2
digitalWrite(Digit1, HIGH);
digitalWrite(Digit2, HIGH);
digitalWrite(A, LOW);
digitalWrite(B, LOW);
digitalWrite(C, HIGH);
digitalWrite(D, LOW);
digitalWrite(E, LOW);
digitalWrite(F, HIGH);
digitalWrite(G, LOW);
digitalWrite(A, HIGH);
digitalWrite(C, LOW);
digitalWrite(D, HIGH);
digitalWrite(E, HIGH);
digitalWrite(F, LOW);
delay(2000);
6
digitalWrite(B, HIGH);
delay(2000);
8
delay(2000);
// Pin 2-8 is connected to the 7 segments of the display.
int A = 2;
int B = 3;
int C = 4;
int D = 5;
int E = 6;
int F = 7;
int G = 8;
int Digit1 = 9; //Digit 1 (+)
int Digit2 = 10; //Digit 2 (+)
// the setup routine runs once when you press reset:
// initialize the digital pins as outputs.
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F, OUTPUT);
pinMode(G, OUTPUT);
pinMode(Digit1, OUTPUT);
pinMode(Digit2, OUTPUT);
// the loop routine runs over and over again forever:
delay(2000);
//4
delay(2000);
//6
delay(2000);
//8
delay(2000);
