When will ATtiny boards be supported in the web editor ?
Thanks,
Ohad
Thanks,
Ohad
@Halevy Support for ATtiny is already in the wishlist, thanks for your feedback!
Today we finally released the support for Chrome OS devices, it is currently in private beta-testing, if you are interested please sign up at Arduino Cloud.
Release Aug 22, version 1.0.4:
Release Sep 14, version 2.0.0:
secret tab improvements: added collapsable instructions, removed sensitive data from download and code previewer for your own code, added secret tab on public code previewer, fixed autosave bug, download compatible version with Java IDE
visual design improvements: fixed icons alignment on Safari, improvement of contrast and legibility on both light and dark theme, debug colors in output
better compilation output for network upload
fixed login flow from editor page
examples in .pde now usable
Any plans to include ESP8266 devices?
Release Sep 26, version 2.1.0:
Updates version 2.1.2:
Updates version 2.2.0
Updates version 3.0.0
Updates version 3.2.6:
Version 4.2.0 and previous:
Plugin updated to 1.1.71
Versions 4.2.1 - 4.2.3:
Version 5.3.0
Versions 5.4.2 - 5.5.3
Versions 5.6.0 - 5.7.0
Version 6.0.0
You could find some of your sketches in a directory named "__root", just move them outside it, if you want it to disappear.
You could also find some empty folders in your sketchbook generated by bugs in the previous version, just remove them if you don't need them.
Versions 6.0.1 - 6.0.6
Version 6.1.0
boards dropdown UI improved and other UI fixes
improved color contrast for snackbars
show IoT Cloud OTA targets in boards dropdown
show device type for OTA targets (linux OTA targets too)
compile and upload for IoT Cloud OTA targets
Implemented boundaries and checks for IoT Cloud sketches
show Tip in sketchbook sidebar context menu to explain why some options are disabled
Open shared sketch with secondary file selected, e.g: layout.png
Improved plugin discovery
Fixed bug on duplicated file tab
Secret tab form fields automatically resize on content
Secret tab values special characters automatically escaped
Fixed download example in public sketch / embedded view
Version 6.2.0
New Feature! Reference sidebar: search for language reference from the searchbar in the sidebar, or select a keyword in the code area, right click, and press "Search Reference".
Some UI bugs fixed.
Check out the new improved Arduino Create Agent version 1.2.0, and remember to enable crash reports!
