Topic: WS2812B SMT chip or module ? (Read 716 times) previous topic - next topic
Vaclav
WS2812B RGB LED comes in two flavors - single SMT chip or a SMT chip mounted on carrier module.
Both types of hardware can be mounted "side by side" - cascaded with input on one side and output on the other , thus soldered / connected / chained together as one unit.
Which hardware would be mechanically preferable if I  need to build non flexible , rigid , strip of four of these?
larryd
I use the chip version mounted on strip PCBs.
This are a bit hard to hand solder, make sure the pads lean towards large.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
CrossRoads
That's where that reflow oven comes in handy ...
larryd
No technical PMs.
Vaclav
Ok,chip it is.
This is just for "proof of concept" - "dead bug" style.
I suppose I could use chewing gum to make them stay put before I attempt to  solder them.
In my limited experience with these SMT buggers , they get stuck to the iron and that is the main problem.
Thanks
larryd
No technical PMs.
