Topic: Project 13 Touchy-feely lamp - Only getting zeros (Read 9366 times) previous topic - next topic
martinloland
Hello, for some reason I am only getting zeros in the serial monitor when I print the sensorValue. I've done some troubleshooting, but without any luck.
Code: [Select]
#include <CapacitiveSensor.h>
CapacitiveSensor capSensor = CapacitiveSensor(4, 2);
  long sensorValue = capSensor.capacitiveSensor(30);
  Serial.println(sensorValue);
  delay(10);
Wiring:
- Still zero when I touch the contact directly
- Done continuity check with multimeter
- My feets are touching the ground
- Connected with USB to computer
Thank you!
dannable
I am attempting to replicate your circuit - what value resistor have you used?
dannable
I used a 1 meg resistor and your code works just fine. Low values (10-40) normal, jumps to 2000+ when my hand is in very close proximity.
martinloland
Thank you for your help! Yep, I also used a 1 meg resistor. Could there be a problem with the library? I dont get any errors when I validate the code. Anything else I could troubleshoot?
dannable
The only physical difference is that I used a crocodile clip to grasp the foil.
Where did you get the capacitance library? I used the one in this link.
koiLunstrum
I got exactly the same problem ... and I download library as the link connection as shown ...I still got only 0
anyone have answer?
dannable
Post your code and a photo of how you have it connected.
packetkiller
I also have the same issue.  I have attempted several ways of getting something to indicate on the stray wire but no go...always 0.
packetkiller
Ok, sometimes you just have to admit when you do something wrong...
I somehow swapped my 220 Ohm and 1M Ohm resistors...
I put them in the correct place and now it works like a champ!
So check your wiring...including components.  I used my meter to check my resistors, as they are both blue and easy to mix up.
