Topic: avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xff (Read 1 time) previous topic - next topic
2n3904
Im using:
- Arduino 1.6.7
- Arduino UNO Rev3 - genuine and not clone
I'm trying to test upload a sketch to ATmega32A but keeps getting errors:
Quote
Warning: platform.txt from core 'MightyCore' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Sketch uses 370 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xff
I'm using the MightyCore.
"Burn Bootloader" is fine.
codlink
So you are programming an Atmega32?  What have you tried so far?
//LiNK
2n3904
Yes im trying to program an ATmega32A-PU using my Arduino UNO as ISP.
Do you know any Atmega core alternative that i can try instead of the MightyCore im using?
DrAzzy
did you remember to disable reset on the uno being used as programmer?
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Arduino_Nut
I received this error yesterday when attempting to update 16U2 firmware on a DUE board following this procedure:
https://www.arduino.cc/en/Hacking/Upgrading16U2Due
I had changed the command line I used to suit my file location, port etc. and received the same error.
Turns out I had the wrong baud rate setting entered, after using baud rate of 19200 upgrade was successful and no more error message.
