Topic: Deep Think Project - Artificial Intelligence Research Project (Read 23657 times) previous topic - next topic
goodinventor
Hello everyone,
I am working on a robotics project, and I thought I should share it with you now that I have gotten some of the hardware and software working. I have named it the "Deep Think Project". It is a research project focused on artificial intelligence and humanoid robotics. Right now I am using the Meccanoid G15, the 86Duino One, and a 9-Volt battery with snap connector. So far I have gotten the servos working. Below is the code.
Code: [Select]
// Deep Think 0.0.0.1
// programmed by George Andrews
// NOTE: This program is designed for the Meccanoid G15 (combined
// with the 86Duino One). It is a part of the Deep Think Project
// (first version of the software for the project). The Deep Think
// Project is designed to advance the intelligence (as well as
// motion and structural capabilities) of humanoid robots. This
// version of the program is designed to do the following.
// 1. Control the output of the LED eyes with the 86Duino.
// 2. Control the 4 Smart Servos with the 86Duino.
// Please note that this version is only intended as a demo to
// establish a basic framework for interfacing the Meccanoid
// electronic parts with the 86Duino One for future development.
#include "MeccaBrain.h"
// pin declarations
int LeftArmDaisyChainPin = 21;
int LEDEyePin = 29;
int RightArmDaisyChainPin = 38;
// class objects
MeccaBrain LeftArmDaisyChain(LeftArmDaisyChainPin);
MeccaBrain LEDEye(LEDEyePin);
MeccaBrain RightArmDaisyChain(RightArmDaisyChainPin);
  // sets LED and servo color to red
  LEDEye.setLEDColor(7, 0, 0, 4);
  LEDEye.communicate();
  LeftArmDaisyChain.setServoColor(0, 0xF1);
  LeftArmDaisyChain.communicate();
  RightArmDaisyChain.setServoColor(0, 0xF1);
  RightArmDaisyChain.communicate();
  // moves arms up
  LeftArmDaisyChain.setServoPosition(0, 255);
  RightArmDaisyChain.setServoPosition(0, 0);
  // wait 1 second
  // moves arms down
  LeftArmDaisyChain.setServoPosition(0, 0);
  RightArmDaisyChain.setServoPosition(0, 255);
  // wait 3 more seconds until next iteration
  delay(3000);
This is a very simple demo starting program, and so does little except insure that the servos, the official Arduino library for the Meccanoid G15, the LED eyes, and my method for writing to the Smart Modules are all functioning properly. I have tweaked the code a few times recently when the code didn't work as I intended, but now I have tested it and the code works. Next I plan on creating some functions for doing different movements with the servos and D/C motors. Any recommendations on new functionality and improvement will be greatly appreciated. I expect this project will take a very long time to complete, if I ever finish it, and I am willing to press on with this project for years. I have researched some possible deep learning algorithms for implementing in this robot, and the one I think will be best for this project is the LAMSTAR algorithm. Size of the program plus bootloader so far is 156KB. I expect that in the near future I will need to upgrade the brain for the robot in order to run the learning algorithm and machine vision.
Thank you all for your support,
goodinventor
goodinventor
Hello everyone,
I have been working on some basic functions for movement, and although the code compiles fine, it doesn't do what I want. The robot takes a long time to initialize, and then it just raises it's left arm. I don't know what's wrong with my code even after hours of looking at it, so I am posting it here. Here is my code.
Code: [Select]
// Deep Think 0.0.0.2
// 1. Perform various moves using functions.
// 2. Control the 2 D/C motors with the 86Duino.
// This version of the software, however, has the following
// additional capabilities compared to the previous version Deep
// Think 0.0.0.1.
// 1. Can interface with the D/C motors as well as the servos and
//    LED eyes.
// 2. Can perform various moves using functions in the program.
// Variables
// pin declarations
int LEDEyePin = 29;
int LeftFootDCMotorPin = 11;
int RightFootDCMotorPin = 13;
// class objects
// Functions
void WaveWithLeftArm()
  // up
  LeftArmDaisyChain.setServoPosition(0, 200);
  // let motors calibrate
  // down
  LeftArmDaisyChain.setServoPosition(0, 127);
  // up again
  // down all the way
void WaveWithRightArm()
  // up
  RightArmDaisyChain.setServoPosition(0, 55);
  // down
  RightArmDaisyChain.setServoPosition(0, 127);
  // up again
  // down all the way
void RaiseLeftHand()
void RaiseRightHand()
void PutDownLeftHand()
void PutDownRightHand()
void TurnLeft()
  analogWrite(RightFootDCMotorPin, 255);
  delay(3000);
void TurnRight()
  analogWrite(LeftFootDCMotorPin, 255);
  delay(3000);
void MoveForward()
  delay(3000);
// bends at elbow with hand in front of robot
void ReceiveWithLeftHand()
  LeftArmDaisyChain.setServoPosition(1, 255);
void ReceiveWithRightHand()
  RightArmDaisyChain.setServoPosition(1, 0);
  // set up DC motors
  pinMode(
  RaiseLeftHand();
  RaiseRightHand();
  delay(2000);
  PutDownLeftHand();
  PutDownRightHand();
  delay(2000);
  WaveWithLeftArm();
  delay(2000);
  WaveWithRightArm();
  delay(2000);
  TurnLeft();
  TurnRight();
  MoveForward();
  delay(2000);
  ReceiveWithLeftHand();
  delay(2000);
  PutDownLeftHand();
  delay(2000);
  ReceiveWithRightHand();
  delay(2000);
  PutDownRightHand();
  delay(2000);
Thank you,
goodinventor
el_supremo
Quote
No it doesn't.
Code: [Select]
 // set up DC motors
  pinMode(
Pete
Don't send me technical questions via Private Message.
goodinventor
Hmmm...my code got changed since I last compiled and uploaded it. I should have checked the code first before posting. I'll fix that right away.
goodinventor
Here is the fixed code. Can you find any other issues?
Code: [Select]
// Think 0.0.0.1.
//    LED eyes.
// Variables
// pin declarations
int LEDEyePin = 29;
// class objects
// Functions
  // up
  // down
  // up again
  // down all the way
  // up
  // down
  // up again
  // down all the way
void TurnLeft()
  delay(3000);
void TurnRight()
  delay(3000);
void MoveForward()
  delay(3000);
  // set up DC motors
  pinMode(LeftFootDCMotorPin, OUTPUT);
  pinMode(RightFootDCMotorPin, OUTPUT);
  RaiseLeftHand();
  RaiseRightHand();
  delay(2000);
  PutDownLeftHand();
  PutDownRightHand();
  delay(2000);
  WaveWithLeftArm();
  delay(2000);
  WaveWithRightArm();
  delay(2000);
  TurnLeft();
  TurnRight();
  MoveForward();
  delay(2000);
  delay(2000);
  PutDownLeftHand();
  delay(2000);
  delay(2000);
  PutDownRightHand();
  delay(2000);
el_supremo
Quote
9-Volt battery
That isn't going to power servos and all the other stuff.
I've never used any of the hardware you're using and I don't have the library so I can't be any further help with this.
Pete
goodinventor
OK. I have tested it though, and the 9-volt battery seems to be able to at least power the servos. It's the DC motors which don't move at all. I should probably get a larger capacity battery at 5V to power the board through the USB client port. Perhaps this program will now work already since I finished the pinMode() statements for the DC motor pins. That may have been what was causing the program to act weird.
By the way, here is the library that I have been using. http://www.meccano.com/meccanoid-opensource
RayLivingston
You're off to a very bad start with your liberal use of delay().  You will very quickly reach the point where your program becomes unresponsive because it's spending most of its time spinning its wheels in delays.  You REALLY need to learn how to write non-blocking code....
Regards,
Ray L.
GoForSmoke
Code: [Select]
// Think 0.0.0.1.
//    LED eyes.
// Variables
// pin declarations
int LEDEyePin = 29;
// class objects
// Functions
  // up
  // down
  // up again
  // down all the way
  // up
  // down
  // up again
  // down all the way
void TurnLeft()
  delay(3000);
void TurnRight()
  delay(3000);
void MoveForward()
  delay(3000);
  // set up DC motors
  RaiseLeftHand();
  RaiseRightHand();
  delay(2000);
  PutDownLeftHand();
  PutDownRightHand();
  delay(2000);
  WaveWithLeftArm();
  delay(2000);
  WaveWithRightArm();
  delay(2000);
  TurnLeft();
  TurnRight();
  MoveForward();
  delay(2000);
  delay(2000);
  PutDownLeftHand();
  delay(2000);
  delay(2000);
  PutDownRightHand();
  delay(2000);
That code is nothing like good. Your robot should be running everything all the time and be able to react to changing conditions immediately, not a chain of delays later.
No biggie. You've not been introduced to microcontrollers and event-driven code before.
This tutorial will teach How to do multiple things at once ... like cook bacon and eggs.
 http://www.gammon.com.au/blink
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
goodinventor
I was planning on implementing this but at the time I was just trying to test the servos and DC motors. Once I got that up and running I was going to use a proper timer for speeding things up. It would also be a good idea to optimize the poorly managed Meccanoid library. I can tell they didn't spend much time writing it. Right now my program doesn't even come close to doing what I want. It is just a basic test of the Servo and DC motor functionality to make sure my hardware setup is OK.
GoForSmoke
It's best to test the hardware pieces each in its own sketch
Learn to do this event-driven (time is one kind of event) code approach and you won't need any timer library.
Run all your inputs, outputs and processes as separate tasks in loop(). It's easier to debug each one alone than all together.
Learn finite state machines to control all that very simply.
Learn these things and then look at your robot with new eyes.
goodinventor
Currently my subsystems that need to be tested are these.
1. Servos (4 in 2 daisy chains)(arms)
2. D/C motors (feet)
3. Obstacle Detection (using ultrasonic sensor)(eyes)
4. LED eyes (decorative part of the eyes)
Over time I will add and change the subsystems.
GoForSmoke
Every one of those products has a library and example code doesn't it? Try that first.
The library source code should tell you how it gets the hardware to work. If you want more, there's the datasheet for the electronics parts and tons of help online.
Really though, learn the simple lesson of many-things-at-once (and BlinkWithoutDelay) before forming your vision of the robot.
You might want to play around with parallel processing and bus systems while you're at it.
darkbluebit
You could use an H-Bridge motor controller to spin DC motors with a separate power source. You can check my example here:
http://darkbluebit.com/arduino-robot-motor-control/
DarkBlueBit.com - My Arduino projects
goodinventor
I already learned how to blink an LED without using delay(). Once I implement it, I can then work on finding a fast interface for connecting the servos. I think the UARTs will do for this job. I am not sure why you mentioned learning parallel processing, since the Arduino can't multi process anyways. Or maybe you were referring to something else?
