Topic: Deep Think Project - Artificial Intelligence Research Project (Read 23659 times) previous topic - next topic
MorganS
Your multiple, multiple gotos seem to be doing this:
Code: [Select]
  while(Time() != 1) {
    //wait
If you get just one of those WLAT1 labels wrong or copy-paste a bit of code without thoroughly checking all the labels inside it then lots of aparrently random things will happen.
My code snippet can be pasted anywhere into the code and it won't jump to a random label elsewhere in the code. That's why gotos are bad.
It is still the wrong way to do it. If you need a delay and there is absolutely nothing else that you program needs to do at the same time, then just use the delay() function. "Waiting for motors to calibrate" is a good example where delay should be used.
"The problem is in the code you didn't post."
goodinventor
Is this better? MorganS, the answer is that I intend to have other things going on, but not just yet. I am working on getting the servos to work right now, but it makes sense to go ahead and write a non-blocking version of delay() because in the near future I will add sensors to the code. I would like to implement multitasking in the near future.
Code: [Select]
// Deep Think 0.0.0.2
// programmed by George Andrews
// NOTE: This program is designed for the Meccanoid G15 (combined
// with the 86Duino One). It is a part of the Deep Think Project
// (first version of the software for the project). The Deep Think
// Project is designed to advance the intelligence (as well as
// motion and structural capabilities) of humanoid robots. This
// version of the program is designed to do the following.
// 1. Perform various moves using functions.
// 2. Control the 2 D/C motors with the 86Duino.
// Please note that this version is only intended as a demo to
// establish a basic framework for interfacing the Meccanoid
// electronic parts with the 86Duino One for future development.
// This version of the software, however, has the following
// additional capabilities compared to the previous version Deep
// Think 0.0.0.1.
// 1. Can interface with the D/C motors as well as the servos and
//    LED eyes.
// 2. Can perform various moves using functions in the program.
#include "MeccaBrain.h"
// Variables
// pin declarations
int LeftArmDaisyChainPin = 21;
int LEDEyePin = 29;
int RightArmDaisyChainPin = 38;
int LeftFootDCMotorPin = 11;
int RightFootDCMotorPin = 13;
// class objects
MeccaBrain LeftArmDaisyChain(LeftArmDaisyChainPin);
MeccaBrain LEDEye(LEDEyePin);
MeccaBrain RightArmDaisyChain(RightArmDaisyChainPin);
// timer variables
unsigned long TimeNeeded;
unsigned long LastTimeUpdate = millis();
// Functions
void WaveWithLeftArm()
  // up
  LeftArmDaisyChain.setServoPosition(0, 200);
  LeftArmDaisyChain.communicate();
  // let motors calibrate
  TimeNeeded = 500;
  if (Time() == 1)
    // down
    LeftArmDaisyChain.setServoPosition(0, 127);
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
    LeftArmDaisyChain.setServoPosition(0, 0);
void WaveWithRightArm()
  // up
  RightArmDaisyChain.setServoPosition(0, 55);
  RightArmDaisyChain.communicate();
  TimeNeeded = 500;
  if (Time() == 1)
    // down
    RightArmDaisyChain.setServoPosition(0, 127);
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
    RightArmDaisyChain.setServoPosition(0, 255);
void RaiseLeftHand()
void RaiseRightHand()
void PutDownLeftHand()
void PutDownRightHand()
void TurnLeft()
  analogWrite(RightFootDCMotorPin, 255);
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void TurnRight()
  analogWrite(LeftFootDCMotorPin, 255);
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void MoveForward()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
// bends at elbow with hand in front of robot
void ReceiveWithLeftHand()
  LeftArmDaisyChain.setServoPosition(1, 255);
void ReceiveWithRightHand()
  RightArmDaisyChain.setServoPosition(1, 0);
// time without delay()
int Time()
  unsigned long Interval = TimeNeeded;
  unsigned long CurrentTime = millis();
  if ((CurrentTime - LastTimeUpdate) > Interval)
    LastTimeUpdate = CurrentTime;
    // time is up
    return 1;
    // time is not yet up
    return 0;
  // set up DC motors
  pinMode(LeftFootDCMotorPin, OUTPUT);
  pinMode(RightFootDCMotorPin, OUTPUT);
  RaiseLeftHand();
  RaiseRightHand();
  TimeNeeded = 2000;
  if (Time() == 1)
    // time is up; continue
    PutDownLeftHand();
    PutDownRightHand();
  if (Time() == 1)
    WaveWithLeftArm();
  if (Time() == 1)
    WaveWithRightArm();
  if (Time() == 1)
    TurnLeft();
    TimeNeeded = 1000;
  if (Time() == 1)
    TurnRight();
  if (Time() == 1)
    TimeNeeded = 2000;
    MoveForward();
  if (Time() == 1)
    ReceiveWithLeftHand();
  if (Time() == 1)
    PutDownLeftHand();
  if (Time() == 1)
    ReceiveWithRightHand();
  if (Time() == 1)
    PutDownRightHand();
  if (Time() == 1)
    // continue...
Whandall
I would suggest to visit less marketing and more technical and programming lectures.
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
goodinventor
Very funny. I have attended none of either. I taught myself everything I know about Arduino and programming.
el_supremo
For those of you who are entangled in this interminable thread, I present two data points.
- see msg #8  in http://forum.arduino.cc/index.php?topic=296831
- read the, also interminable, thread about his UNOS "operating system" http://forum.arduino.cc/index.php?topic=289888
Pete
Don't send me technical questions via Private Message.
goodinventor
That was an interesting "Rube Goldberg" experiment, although I think it does have a use. I just designed it wrong and put in the wrong features. On top of that, I did not understand the AVR architecture well enough. But what does that old failed project have to do with this?
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
goodinventor
I saw and read it, but I do not understand. My projects were never meant to be some sort of commercial *cough* project. Rather, I posted them because I thought they were incomplete and you all (who know more than I do) could help me. I am not in it for fame or money. I am doing this purely for my own amusement although I also want to share my projects. Do you understand better now?
JimboZA
Seems OP took Robin2 at his word in January 2015 when he said...
Quote
Take a year off
... and here we are.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
goodinventor
During that time I've been doing research and improving my programming skills, though I really could use tons of improvement still.
AWOL
Quote
Forget you ever heard of "goto", please.
Robin2
@goodinventor, your youth and enthusiasm are wonderful.
The gap between your apparent abilities and what you aspire to is too wide for useful assistance on this Forum. To use my earlier analogy, you are like a 2nd week musician trying to participate in a guitar master class at the standard of Jimi Hendrix. You have not yet acquired either the technical skills or the background knowledge.
What concerns me is that by struggling unsuccessfully with something that is now far out of your reach you will miss the opportunity for the step-by-step acquisition of the skills that would allow you to contribute to Artificial Intelligence Research in the future.
...R
GoForSmoke
Is this better?
Code: [Select]
// Think 0.0.0.1.
//    LED eyes.
// Variables
// pin declarations
int LEDEyePin = 29;
// class objects
// timer variables
// Functions
  // up
  TimeNeeded = 500;
  if (Time() == 1)
    // down
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
  // up
  TimeNeeded = 500;
  if (Time() == 1)
    // down
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
void TurnLeft()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void TurnRight()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void MoveForward()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
int Time()
    // time is up
    return 1;
    return 0;
  // set up DC motors
  RaiseLeftHand();
  RaiseRightHand();
  TimeNeeded = 2000;
  if (Time() == 1)
    PutDownLeftHand();
    PutDownRightHand();
  if (Time() == 1)
    WaveWithLeftArm();
  if (Time() == 1)
    WaveWithRightArm();
  if (Time() == 1)
    TurnLeft();
    TimeNeeded = 1000;
  if (Time() == 1)
    TurnRight();
  if (Time() == 1)
    TimeNeeded = 2000;
    MoveForward();
  if (Time() == 1)
  if (Time() == 1)
    PutDownLeftHand();
  if (Time() == 1)
  if (Time() == 1)
    PutDownRightHand();
  if (Time() == 1)
    // continue...
I don't think that code will do what you seem to think it will do.
It certainly won't act like the code with the delays would. Ohhhhh no!
You did NOT learn the BWOD lesson but you do seem to have grasped the know-how-long-it's-been part of it. Spend some time on the implications, make 2 leds blink at different rates or 2 serial messages print at different rates, just to start.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
AWOL
Here's a simple challenge I propose to people who think they've fully grasped the BWOD Principle, and you can do it on a bare Arduino: make the LED on pin 13 fade up down, without using delay.
For bonus marks, add a potentiometer and vary the fade rate.
MorganS
Code: [Select]
// Think 0.0.0.1.
//    LED eyes.
// Variables
// pin declarations
int LEDEyePin = 29;
// class objects
// timer variables
// Functions
  // up
  TimeNeeded = 500;
  if (Time() == 1)
    // down
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
  // up
  TimeNeeded = 500;
  if (Time() == 1)
    // down
  if (Time() == 1)
    // up again
  if (Time() == 1)
    // down all the way
void TurnLeft()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void TurnRight()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
void MoveForward()
  TimeNeeded = 3000;
  if (Time() == 1)
    // continue...
int Time()
    // time is up
    return 1;
    return 0;
  // set up DC motors
  RaiseLeftHand();
  RaiseRightHand();
  TimeNeeded = 2000;
  if (Time() == 1)
    PutDownLeftHand();
    PutDownRightHand();
  if (Time() == 1)
    WaveWithLeftArm();
  if (Time() == 1)
    WaveWithRightArm();
  if (Time() == 1)
    TurnLeft();
    TimeNeeded = 1000;
  if (Time() == 1)
    TurnRight();
  if (Time() == 1)
    TimeNeeded = 2000;
    MoveForward();
  if (Time() == 1)
  if (Time() == 1)
    PutDownLeftHand();
  if (Time() == 1)
  if (Time() == 1)
    PutDownRightHand();
  if (Time() == 1)
    // continue...
So, let me understand this, the Time() function returns true if it is more than TimeNeeded milliseconds since the last time it returned true? What if you haven't used it in a while? You can't get a negative delay.
Try and take on AWOL's challenge. It's a little fuzzy on the details so you may need to ask him for clarification but I have a solution in mind that will be only 20 lines of code.
