Topic: First Project: LEDs (Read 336 times) previous topic - next topic
_OverLord_
I just started using Arduino but every time I make a project it creates errors that I dont know how to fix.
Here's my sketch.
if (SwitchState == LOW) {
   digitalWrite(3, HIGH);
   digitalWrite(4, LOW);
   digitalWrite(5, LOW);
 else{
   digitalWrite(3, LOW);
   digitalWrite(5, HIGH);
   delay(250);
   digitalWrite(4, HIGH);
   delay(250);
Delta_G
Go have a look at some of the example sketches.  You have to have your code in functions.  Two functions, setup and loop MUST be defined for your sketch.  Again, go look at some of the examples and you'll see how this stuff is supposed to be laid out.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
CrossRoads
Yes, you're missing the beginning, and end, which can be inferred to be:
Code: [Select]
byte switchPin = 2;
byte switchState;
void setup(){
pinMode (3, OUTPUT);
pinMode (4, OUTPUT);
pinMode (5, OUTPUT);
pinMode (switchPin, INPUT_PULLUP);
void loop(){
switchState = digitalRead (switchPin);
// then your code
} // end of loop()
CrossRoads
check upper/lower case consistency in naming also.
SwitchState is a different variable than switchState, so you need to make those match.
