Topic: Record audio from a microphone to an SD card? (Read 19742 times) previous topic - next topic
Grumpy_Mike
Same as reply #22 only you do a bit more shifting.
Code: [Select]
byte0 = value & 0xff;
byte1 = (value >> 8) & 0xff;
byte2 = (value >> 16) & 0xff;
byte3 = (value >> 24) & 0xff;
pjrc
#31
Mar 03, 2016, 01:25 am Last Edit: Mar 03, 2016, 01:30 am by Paul Stoffregen
By the way, how you can achieve a higher sampling rate?
If you're willing to go with 32 bit ARM, the Teensy audio library has working 44.1 kHz play and record, and a lot more.
This 48 minute tutorial video shows many of the features.
https://www.youtube.com/watch?v=wqt55OAabVs
However, recording the SD card isn't show in the video.  But you can find the example code here:
https://github.com/PaulStoffregen/Audio/blob/master/examples/Recorder/Recorder.ino
If you really want to stay on 8 bit AVR, you're probably going to have to settle for lower quality sound.  Moving so much data around on a slow chip without DMA is really hard.  On a faster 32 bit chip with an optimized library that uses DMA to efficiently bring the audio in and out, it's much easier.
Lucario448
I don't know what happened, but I thought I've replied that last post. I've said that the board looks awesome, and already acknowledged that with a AVR MCU I can't expect a recording sampling rate higher than 8 KHz; but, I wanna do this with what I have on hand. And also wondering if by writing data directly to the SD card there would be a jitter in the sampling rate.
On the other hand, I made this sketch for my audio recorder, compilable as it is, for now it is not well documented; but I hope that the code is self-explanatory.
I'm open to hear any suggestion, improvement, optimization, etc.; that I should make to this code. If you think that a comment is redundant or irrelevant, then just ignore it (again, it is not well documented yet).
Now here is the code:
Code: [Select]
  SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10
#include <SPI.h>
#include <SD.h>
PROGMEM const byte header [44] =
 // This contains the header of a WAV file. Without this, it is not recognized as such.
 // 44 bytes long.
 0x52, 0x49, 0x46, 0x46, 0x00, 0x00, 0x00, 0x00, 0x57, 0x41, 0x56,
 0x45, 0x66, 0x6D, 0x74, 0x20, 0x10, 0x00, 0x00, 0x00, 0x01, 0x00,
 0x01, 0x00, 0x40, 0x1F, 0x00, 0x00, 0x40, 0x1F, 0x00, 0x00, 0x01,
 0x00, 0x08, 0x00, 0x64, 0x61, 0x74, 0x61, 0x00, 0x00, 0x00, 0x00
const byte firstPos = 4;
// Position in the file to write down the overall file size minus 8.
const byte secondPos = 40;
// Position in the file to write down the overall file size minus 44.
const byte button = 2; // Pin for the button.
const byte led = 4;
// Pin for the status LED. Unfortunately, the built-in LED is already
// used by the SPI.
byte buttonState = LOW;
// Remember the button state before test the loop's condition. LOW is default or
// not pressed.
File recording;
 pinMode(button, INPUT);
 pinMode(led, OUTPUT);
 pinMode(10, OUTPUT);
 ADCSRA = (ADCSRA & 0xf8) | 0x04; // ADC fast mode
 digitalWrite(led, LOW);
 if (!SD.begin(10)) {
   errorStatus(); // SD card failure
 if (SD.exists("REC001.wav")) {
   if (!SD.remove("REC001.wav")) {
     errorStatus();
     // Any previous (or incomplete) recording should be deleted
     // in order to make a new one. This error might occur due to
     // write-protected or damaged card.
 if (digitalRead(button) == HIGH) {
   recording = SD.open("REC001.wav", FILE_WRITE);
   if (recording) {
     writeHeader();
     standby();
     buttonState = LOW;
     record();
     finalize();
     finishStatus();
     errorStatus(); // Might be write-protected card or else
void writeHeader() {
 // Puts the "idetification" of a typical WAV file (because .wav isn't enough)
 for (byte pos = 0; pos < sizeof(header); pos++) {
   recording.write(pgm_read_byte(&header[pos]));
void record() {
  * This is how the recording process works. This will last until (normally)
  * the press of the button.
  * DO NOT RESET OR POWER-down THE BOARD WHILE IN THIS STATE, UNTIL THE STATUS LED
  * GETS IN THE FINISHED STATE; otherwise file corruption and/or SD card damage will occur.
  * Exceeding 4 GiB file size (149hr 7min 50sec of audio recording), when meeting a file system's
  * limitation, or filling up the memory; may cause unexpected behavior.
 byte sample = 0;
 digitalWrite(led, HIGH);
 while (buttonState == LOW) {
   sample = analogRead(A0) >> 2;
   recording.write(sample);
   buttonState = digitalRead(button);
   delayMicroseconds(0);
   // Make a trial an error test to know the amount of delay
void finalize() {
 // Fills up two necessary variables in the file's header,
 // then ensures a successfully saved recording.
 byte finalValue[4];
 unsigned long fileSize = recording.size();
 unsigned long riffSize = fileSize - 8;
 unsigned long dataSize = fileSize - 44;
 finalValue[0] = riffSize & 0xff;
 finalValue[1] = (riffSize >> 8) & 0xff;
 finalValue[2] = (riffSize >> 16) & 0xff;
 finalValue[3] = (riffSize >> 24) & 0xff;
 // Is possible to make a fuction that returns an array of bytes?
 recording.seek(firstPos);
 recording.write(finalValue, 4);
 // Check if already in little-endian order
 finalValue[0] = dataSize & 0xff;
 finalValue[1] = (dataSize >> 8) & 0xff;
 finalValue[2] = (dataSize >> 16) & 0xff;
 finalValue[3] = (dataSize >> 24) & 0xff;
 recording.seek(secondPos);
 recording.close();
void errorStatus() {
 // The status LED endlessly indicates a critical error.
 // The only way out, is by resetting the MCU (reset button or power down).
 while (true) {
   delay(250);
   delay(250);
void finishStatus() {
/* The status LED endlessly indicates a successfully saved recording.
 * The only way out, is by resetting the MCU (reset button or power down).
 * From here, it is safe to reset or power-down the board.
 * If there is a way to generate filenames automatically, then this function
 * will become useless.
 while (true) {
void standby() {
 // The status LED endlessly indicates that the MCU is ready to record
 // (until you press the button)
 while (true) {
CrossRoads
Thanks, the board is quasi developmental, quasi datalogger, whatever you might find a SD card & RTC & RS232 & dual hardware serial ports with lots of SRAM (16K, twice that of a Mega) useful for.  I wired one up to prove out a standalone programmer because it had the right parts - 3.3V buffered SD card and 400mA 3.3V regulator. 150mA from an Uno/Mega is not enough to power an SD card.
I think fat16lib had the code running on a 328P board also. The fast ADC and DAC are what allow the higher sampling rate. 8 or 10 bits at lower rates don't sound that good for audio. I was going for electronic drums eventually, will get there at some point.  Need to re-visit  the trigger and peak detect circuit I had working back on 1990 before we bought a  house and moved and started doing all that homeowner stuff.
