Topic: 1284P - Compiling error (Read 3332 times) previous topic - next topic
hansibull
What kind of core are you using the the 1284P? If you're ready to jump up to the IDE v1.6 you may want to try MightyCore. I haven't tested it with the NRF24L01 libraries, but the other you mentioned works fine. You also got som additional options, like clock frequency, Brown out detection and a variant option (if you have a 1284 instead of the 'P' version). My perception is that it require very little work making libraries compatible with the 1284P (and the rest of the family).
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
Watcher
Thanks hansibull, but I am still using 1.0.6 for now ..
pert
WestFw published a new version of Optiboot that fully supports 1284p (tested by yours truly), which also provides pins_arduino.h with the pinout used by Bobuino.
I don't see any pins_arduino.h in the optiboot repository. boards.txt and boards-1.6.txt have
Code: [Select]
optiboot1284.build.variant=arduino:standard
which doesn't make sense to me because that's the variant used for Uno, etc.
Try https://github.com/JChristensen/mighty-1284p
Watcher
Quote
Wow... Thanks pert!   That eventually worked. Everything now compiles!
Thanks very much!
Which board option do you use for 16MHz. The "maniacbug" 1284p using optiboot 16 MHz ?
I also need to decide on the pinout (pin mapping) before I get the PCB done... I ll be using the SMD version of the chip.
pert
You can use avr-developers.com pinouts 16MHz using Optiboot, Bobuino and Skinny Bob, Mighty Mini 1284p @ 16MHz, Optiboot @ 1Mbps or "maniacbug" Mighty 1284p 16MHz using Optiboot. They are all 16MHz except for Mighty Mini 1284p @ 8MHz. I'm not sure what the best pinout is, there are so many of them. I recently put together a list(let me know if anyone wants it) of 12 different Arduino pinouts used with ATmega1284P. It's a shame that Arduino never made an official ATmega1284P based board just so that we would have a standardized pinout.
Watcher
Quote
So true...
Does pinout make much difference when it comes to software library support?
oric_dan
Look at the chip diagrams in the pins_arduino.h files for each variant. The Bobuino pinout is closest to anything in the Arduino world, and essentially congruent with the Arduino-UNO pinout for the first 20 pins. Eg, D3..D0 = Tx1,Rx1,Tx0,Rx0, and D13..D10 = SPI Sclk,MISO,MOSI,SS, &etc.
The other variants are in no way similar to anything in the Arduino world.
pert
It can. Lets take the Ethernet library included with the JChristensen/mighty-1284p core as an example. The patch to add ATmega1284P compatibility is in utility/w5100.h line 330:
Code: [Select]
#elif defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) \
  || defined(__AVR_ATmega644__)  || defined(__AVR_ATmega644A__) \
  || defined(__AVR_ATmega644P__)  || defined(__AVR_ATmega644PA__)
  inline static void initSS()    { DDRB  |=  _BV(4); }
  inline static void setSS()     { PORTB &= ~_BV(4); }
  inline static void resetSS()   { PORTB |=  _BV(4); }
So this means PB4 will be used for the W5100 SS. In the mighty-1284p:standard and mighty-1284p:avr_developers variants this is mapped to Arduino pin 4. In the mighty-1284p:bobuino variant this is mapped to Arduino pin 10. The Ethernet shield connects the W5100 SS to Arduino pin 10.
pert
An issue I've run into with the mighty-1284p pins_arduino.h files is that only the avr_developers variant has license information and that repository doesn't have a license. So can I use the other variant files in my own project? I can reference the variant in the mighty-1284p core but that is not as user friendly because they will need to have it installed and referencing a non-existent variant produces a cryptic java error message in the Arduino IDE.
westfw
Quote
Correct; optiboot doesn't include any variants, and points it's 1284 boards.txt entry at "standard" because that will mostly compile (the core mostly has CODE for 1284, just not pin_defs.)
