Topic: Safe to jump output pins to serial pins? Or danger of damaging something? (Read 1 time) previous topic - next topic
Wout_fisheye
I've got a Tinkerkit (RIP) DMX master shield, which communicates with Arduino on pin 3 and 4. Can I safely jump these pins to pin 0 and 1 to use the hardware serial port? Or am I damaging pins in some way?
+ would I have to set pins 3 and 4 to INPUT?
Thanks,
Wout
DrAzzy
The pins must be inputs, if they're outputs, it could damage the chip. Connecting them with a resistor ( say 1k) instead of a jumper is safer.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Wout_fisheye
Alright, and the serial port RX would still get triggered with the lower voltage due to the resistor?
Or is it in this case just limiting current?
DVDdoug
Quote
Why?   What are yoiu trying to accomplish?   What's wrong with using pins 3&4 to communicate with the DMX, and leaving pins 1&2 to communicate with the computer/USB?
As a general rule, I wouldn't mess with pins 1&2...  I'd leave them for downloading, for the serial monitor, and otherwise communicating with the computer in the usual way.
DrAzzy
It's just to limit current, in case you screw up and set a port output. Ideally, you wouldn't connect 3 and 4.
But I just realized, a 1k resistor won't work, you need something smaller than 1k going to Rx on the arduino, since that's also connected to Tx on the usb-serial adapter through a 1k resistor (on the Uno). You could of course directly connect them if the shield was no longer connected to pins 3 and 4.
Ugh.
He probably wants them on hardware serial, due to the abundant limitations of software serial.
pwillard
That's why people buy USB-TTL-Serial boards.  Pins 0 and 1 are "occupied" unless you remove the Arduino bootloader from the board.
DrAzzy
The bootloader has nothing to do with the physical connections to the pins, the bootloader is software. You mean the USB-serial adapter, I think.
Grumpy_Mike
The boot loader is the software that sets these pins to be inputs and outputs. If you remove that and program through the SPI then you can use those pins for what ever you want.
