Topic: Motors work with arduino UNO, don't work with 101 (Read 366 times) previous topic - next topic
moodydog
Currently have two parallel motors connected to digital pin 9 on UNO. Works perfectly, have the same electrical configuration, swapped the board to a 101, same connections, motor doesn't work. Have tried on a number of digital pwm pins (I'm controlling via a MOSFET so I can alter the speed).
Any ideas as to why it doesn't work? Is the code slightly different for the 101 to control motors?
Code: [Select]
#include <Servo.h>
Servo myservo;
int pos = 50;
const int motorPin = 9;
  myservo.attach(5);
  pinMode(motorPin, OUTPUT);
  digitalWrite (motorPin, HIGH);
  for (pos = 50; pos <= 120; pos += 1){
    myservo.write(pos);
    delay(30);
  for (pos = 120; pos >= 50; pos -= 1){
    myservo.write(pos);
    delay(30);
CrossRoads
What's the MOSFET?
Uno has 0/5V level outputs. What does 101 have? 0/3.3V perhaps?
moodydog
It does :)
I am using ths;
Minimum gate thresh' is 1V ; Max 2V
http://uk.rs-online.com/web/p/mosfet-transistors/5411196/?searchTerm=541-1196&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D504E266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B337D5B5C732D2F255C2E2C5D5C647B332C347D2426706F3D313426736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3534312D3131393626
CrossRoads
"The board operating voltage and I/O is 3.3V but all pins are protected against 5V overvoltage."
So you need a logic level MOSFET with a gate voltage < 3.3V.
You may need to go to a surface mount part
http://www.digikey.com/product-search/en/discrete-semiconductor-products/fets-single/1376381?k=n-channel%20mosfet
Or change your design to bring the 3.3V level up to 5V level and let that switch a part like AOI514:
http://www.digikey.com/product-search/en?keywords=aoi514
Got a datasheet for IRL520NPBF?
http://www.irf.com/product-info/datasheets/data/irl520npbf.pdf
At 2V Vgs, it barely turns on.
DrAzzy
IRF3708PBF works pretty well at 3.3v on gate. It's not rated for that, but per the graphs in the datasheet, it's pretty good at 3.3v - it's the best through-hole MOSFET I was able to find for 3.3v gate voltages and a decent amount of current.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
moodydog
Aah, OK
So I've swapped the transistor around, as I also had a couple of IRF520NPBF, and it seems to work so I'll use it for the while. I'll look into the IRF3708PBF!
Thanks,
