Topic: This is possible to create a communication channel with 2 leds ? (Read 483 times) previous topic - next topic
NiqueLamard
Hi , i need you're help , this is possible to create a communication channel with 2 leds ?
Thanks :D
pwillard
An LED can both emit and to some degree sense light.  With some help you can possibly make a sender/receiver with 1 led... thus only needing 1 led at each end.
Since LED's are not super sensitive... I doubt it would work very well... or very fast
Or were you talking about a different setup...
details  details
NiqueLamard
Thanks for you're answer , i have a homework yo do and the question of the  homework is " We can create a communication channel with only 2 leds?"
I think it's not possible , but i want to know what you think about it
PaulRB
Two ir leds and 2 ir receivers, yes. The homework question is very wooley. Is that all it said?
runaway_pancake
If we both know Morse code or other agreed standard and use LEDs like Aldis lamps then that's a communication channel using only two LEDs (as far as I'm concerned.)
You should try a web-search some time ("communication with 2 LEDs") -
http://www.merl.com/publications/docs/TR2003-35.pdf
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
