Topic: floating point precision: is true double possible? (Read 11845 times) previous topic - next topic
mowcius
Quote
Earth's diameter in m (6371000)
That might be your issue
Quote
Earth's Diameter at the Equator: 7,926.28 miles (12,756.1 km)
Earth's Diameter at the Poles: 7,899.80 miles (12,713.5 km)
Mowcius
borref
Quote
Is there any other conversion required?
Arguments for latitude and longitude need to be passed as radians (not degrees). Could this be what you have missed?
The return value (also in radians) must then be multiplied with the earth radius. For this I use the the IUGG mean radius defined as 6371009 meters.
http://en.wikipedia.org/wiki/Earth_radius
AWOL
Quote
though am not getting a valid result (getting 50~300m
Have you checked your datum?
For instance, the UK OS datum produces errors of about this magnitude, compared to the WGS datum used by GPS.
