Topic: FYI Making DuPont jumper wires. (Read 6189 times) previous topic - next topic
larryd
Feb 04, 2016, 10:55 pm Last Edit: Feb 05, 2016, 09:47 pm by LarryD
I thought others might be interested in this discussion making DuPont jumper wiring.
Attached is a PDF file for the discussion.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
CrossRoads
pwillard
Better than 99% of all "Instructables".  Thanks.
weedpharma
Nice job. But why not let those nice people in China do it for you? The cost is very reasonable and downright cheap if you take time into account.
Weedpharma
xl97
Weedpharma
Can you provide a link?
Can you get specific/custom combinations? (count and color?)
@LarryD  -  (karma added, nice job!)
weedpharma
#6
Feb 05, 2016, 04:50 pm Last Edit: Feb 05, 2016, 04:53 pm by weedpharma
For general purpose leads, what you can get from China are suitable. Various or fixed lengths, rainbow colours, male and female combinations are all available.
Of course for specific cable lengths or colours DIY is the way.
http://www.dx.com/s/DuPont+cables
Weedpharma
larryd
#7
Feb 05, 2016, 06:59 pm Last Edit: Feb 05, 2016, 07:00 pm by LarryD
Thank you.
I believe most here make their own cabling, at least if you are seasoned.
It is nice to have the ability to make your own wire lengths to conform to your project's dimensions.
I have some ready made wires I use with breadboards, most are 26AWG.
However, when it comes time to packaging a project, I always make up my own wiring harnesses.
No technical PMs.
DrAzzy
#8
Feb 05, 2016, 07:07 pm Last Edit: Feb 05, 2016, 08:16 pm by DrAzzy
That's a very nice guide - I never knew about the strip serving a specific purpose. I think that will help significantly.
Weedpharma
That's a nice source - their prices for individual (eg, not ribbon cable) jumpers is reasonable, though you have to remove the plastic 1p housings they put on them (how obnoxious).
polulu sells jumpers with just the bare pins (ready to drop into housings) in various lengths - but at eye-watering prices. I'm looking at their white ones for a project, and the cables would cost more than the entire rest of the project combined, including the PCBs.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
larryd
#9
Feb 05, 2016, 09:41 pm Last Edit: Feb 05, 2016, 09:51 pm by LarryD
A few more additions.
I will add images to the PDF in post #1.
No technical PMs.
terryking228
Hi, Nice Instructable; I will link to it on the ArduinoInfo.Info  HERE:  That also shows nice 3-pin cables that make it easy to connect servos and many other 3-pin devices.
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
wilykat
Weedpharma
For a large run, maybe but if one is building prototype, a DIY solution may be better while one experiment on what works. Plus DIY solution gets the cable in a few minutes. Cable from China may take a few weeks.
+rep for useful pictures. I have the right tool but I've had bits of trouble getting it done right. Leaving that sprue helps a lot on proper alignment.
PS what about ribbon cable?  Typical ribbon cable have 0.05mm spacing which is fine for crimp on 2 rows connector like IDE cable but if you're doing single row cable, the spacing is off and if you don't trim the end at an angle you'd end up with middle wires a little lumpy.
larryd
You can get ribbon cable that is 24 or 22 AWG.
The ribbon cable I use in IDC connectors however, is 28 AWG.
I get all my jumper wires from multi-conductor cables like these:
No technical PMs.
larryd
No technical PMs.
Southpark
#14
May 01, 2017, 05:01 am Last Edit: May 01, 2017, 05:09 am by Southpark
One more thing..... make sure to push the plastic tab in real good before inserting the wire/crimp assembly into the plastic casing. Use a tiny screw-driver or thin paper-clip, and push that tab inwards ----- right into the slot. Get a good inward angle on it. Do all this before inserting the metal/wire/crimp assembly into the plastic casing. Sometimes, wires slide out from the plastic casing only because the tabs were not properly pushed in (to get a good inward angle) to begin with.
