Topic: Two servo running simultaneously in opposite direction.  (Read 2824 times) previous topic - next topic
Aswinth
Hi all,
I am a beginner in arduino programming. I tried to write a program to run two servo motors (Hobby motors - Vega robotics V3003) in opposite direction. That is one from 0-180deg and another from 180-0 degree.
The code which i wrote works well but the problem is both motors does not rotate simultaneously, only after the first servo moves from 0-180 the second servo moves from 180-0. I am using arduino mega board.
Please help me with the code, thanks in advance
jremington
Post the code, as described in "How to use this forum".
I hope you are not trying to power the servos from the Arduino.
zoomkat
A very simple example of getting servos to rotate in opposite directions.
Code: [Select]
//zoomkat 10-09-14 serial servo test
//type servo position 0 to 180 in serial monitor
//opposite side servos rotate together
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(8);
  myservo2.attach(9);
  Serial.println("servo-test"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the String readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured String
    int n = readString.toInt();  //convert readString into a number
    myservo1.write(n);
    myservo2.write(180-n); //turns opposide servo in desired direction
    readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
MarkT
using delay() while reading Serial is a fundamental misunderstanding of I/O - read till the end
of line or separator character, using if, not while.  When you see the separator
then process the chars so far, not before.  Calling delay just means you code won't work at high
baud rates!
Code: [Select]
void loop ()
  if (Serial.available ())
    char c = Serial.read () ;
    if (c == '\n')   // assume newline is separator
      int n = readString.toInt () ;
      myservo1.write (n) ;
      myservo2.write (180-n) ;
      readString = "" ;
      readString += c ;
  ... any other stuff running in parallel
zoomkat
Quote
Not really, it gets around having to add some type of end of data delimiter for simple testing purposes. Also, the code I posted compiles, what happened to yours?   8)
MarkT
Perhaps you don't understand that "...  any other stuff running in parallel" is a hint that
my way interworks with other code nicely in a way your's cannot.  Yes it doesnt compile.
zoomkat
And what do you not understand in the statement "A very simple example of getting servos to rotate in opposite directions."?  Work on getting yours to compile!  8)
hieloiceberg
I know little knowledge of coding but swapping the wires on the motor and potentiometer (inside the servo) did it for me.
nielyay
Hi.
Quote
Please input your code.
Code: [Select]
#include <Servo.h>
Servo myservo;
int pos = 0;
  myservo.attach(9);
  for (pos = 0; pos <= 180; pos += 1)
    myservo.write(pos);
    delay(15);
  for (pos = 180; pos >= 0; pos -= 1)
    myservo.write(pos);
    delay(15);
*use the simple code on the Arduino software toolbars. Examples > Servo > Sweep
