Topic: Simpler tipping calculations for balancing robot  (Read 1 time) previous topic - next topic
jremington
Quote
Even if you can get an accuracy of 1 deg with sensor fusion it is not good enough.
Nonsense.
charliesixpack
MarkT
But its rate of change of tilt that matters, absolute angle is best corrected from wheel acceleration
as I've mentioned (partly because the distribution of mass may change and thus the perfect balance
angle will be different from run to run if the battery is moved/changed or a payload added).
jremington
#18
Feb 14, 2016, 05:11 am Last Edit: Feb 14, 2016, 06:19 am by jremington
It is interesting that for a falling inverted pendulum, the rate of change of theta (tilt) is proportional to theta (for theta << 1 radian).
This follows directly from the equation of motion about a point of unstable equilibrium:
theta dot = sqrt(g/l)*theta
where l is the distance from the pivot point to the center of mass.
charliesixpack
(theta dot)dot = sqrt(g/l)*theta
jremington
#20
Feb 14, 2016, 05:09 pm Last Edit: Feb 14, 2016, 05:14 pm by jremington
Actually, from freshman physics,
(theta dot) dot = (g/l)*theta
for small theta. Solving this leads to what I posted in reply #18 (apropos of MarkT's statement) and is left for as an exercise for the reader.
