Topic: From schematic to breadboard design  (Read 1 time) previous topic - next topic
arduNew1
Feb 10, 2016, 11:25 pm Last Edit: Feb 10, 2016, 11:30 pm by arduNew1
Hello everyone,
I am trying to design a circuit using a schematic design into a breadboard, but it does not work. Wondering if someone can take a look to see if I have a bad configuration: I attached the schematic and my breadboard design.
Also if I am using a battery 3.7v 240mAh but the project requieres a 3.7v at 100mAh, I will not be able to use mine at 240mAh or it does not matter at all?
Thanks
codlink
#1
Feb 11, 2016, 01:43 am Last Edit: Feb 11, 2016, 01:44 am by codlink
First, that fritzing image is digusting.  It would be better if you actually took an infocus pic of your breadboard.  We still have no idea if you connected everything correctly.
Second, its bad design to have a button pin float while not pressed.  It needs a pull up resistor.
While your at it, please post the code here in code tags.  Other than that, your statement of " it doesn't work" doesn't help us either.  State what it does compared to what it supposed to do.  Also give details on what your project is.
//LiNK
