Topic: Expected `;' before '{' token (Read 1 time) previous topic - next topic
roberto03
Hi, I'm running the following code
Code: [Select]
#include <CapacitiveSensor.h>
CapacitiveSensor capSensor = CapacitiveSensor(4,2);
int threshold = 1000;
const int ledPin = 12;
  pinMode(ledPin, OUTPUT);
  long sensorValue = capSensor.capacitiveSensor(30);
  Serial.println(sensorValue);
  if(sensorValue > threshold)
    digitalWrite(ledPin, HIGH);
   digitalWrite{ledPin, LOW};
  delay(10);
And I don't understand why they tell me this error
Code: [Select]
p13_lamp_ino.ino: In function 'void loop()':
p13_lamp_ino:23: error: expected `;' before '{' token
CrossRoads
I'm guessing you don't have this library located in the correct place:
CapacitiveSensor.h
Scroll up in the bottom part of the IDE window, or drag the bottom up to make the viewing are bigger, and see if that is noted.
roberto03
I'm sorry, but there is no signaled problem with the
"CapacitiveSensor.h"
The only error is:
oqibidipo
Look very closely at the first digitalWrite(...) and you will see what is wrong with the second digitalWrite{...}.
roberto03
It works now, almost impossible to spot.
A big thank you then...
