Topic: Optiboot - improved Arduino bootloader (Read 24274 times) previous topic - next topic
Cathedrow
I've developed a new bootloader for 168 and 328 Arduinos. It has some nice features:
  • Faster upload speed.
  • Watchdog handling (Adaboot mods).
  • More sketch space - the bootloader is a quarter of the Arduino bootloader size, giving 1.5K of extra flash space.
  • Written in C, without large chunks of assembly.
  • Easy install.
  • Compatible with all 168 and 328 Arduinos.
Come and get it! http://code.google.com/p/optiboot/
vxir
Heh... check out http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1270564546/0.  I did mine Mar 19, you did your Apr 03.  Before that no bootloaders were under source control!  BTW, check out the poll... 58% of the people (not many so far) don't know what a code repo even is :-(.  Bummer for us!  Hope you don't mind if I dig into how you slimmed yours down and incorporate some changes!  You are welcome to take my "pin 13 fades while waiting for DL" or my "double click reset for extra long DL" features if they will help you!
keeper63
Here would be an interesting contest idea: The 512 byte bootloader contest (although Peter may have won it so far!).
;D
It would be interesting, though, to see who could come up with the most functionality in a bootloader and keep it under 512 bytes. Could it be done in less? 256 bytes...?
Kinda like the "intro" competitions you see demo coders do; maybe get some Arduino vendors to donate prizes...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Cathedrow
vxir: Have a look at the hardware directory installation method. It's a recent feature (Arduino 18), but it is very beginner friendly. Unfortunately the bootloader is very tight in there - I think there are only 4 bytes free, so I won't be adding much extra functionality soon. I was pondering switching to 250kbaud, once the Arduino distribution includes the latest Avrdude which supports non-standard baud rates.
cr0sh: There isn't much point in going below 512 bytes. On the ATmega328, the smallest boot block you can have is 512 bytes, so if you go smaller you don't gain any extra program flash space. The next useful size on the 168 is 256 bytes - and I really don't think it would be possible to squeeze things that tight.
mowcius
Hmm, I too like that idea.
Now I just need an AVR programmer to test this new bootloader...  :P
Mowcius
Cathedrow
mowcius: You can use a second Arduino as a programmer: http://arduino.cc/en/Tutorial/ArduinoISP
keeper63
Quote
Interesting thing to know; I wonder if a "bootloader developer FAQ" should be created...
Cathedrow
Bootloader developer FAQ: http://www.atmel.com/dyn/resources/prod_documents/8271.pdf
(Which looks remarkably like the Atmel ATmega328P data sheet, by the way  ;) )
bill2009
#8
Apr 17, 2010, 01:35 am Last Edit: Apr 17, 2010, 01:35 am by bill2009 Reason: 1
Great, thank you.  I'll be trying this out as a bootloader but also using it to understand the source.  Your code is MUCH easier to read than the standard because of all the conditional assembly for other processors.  A couple of questions:
1) Near the start of "main" you comment:
Code: [Select]
/* C zero initialises all global variables. However, that requires */
/* These definitions are NOT zero initialised, but that doesn't matter */
/* This allows us to drop the zero init code, saving us memory */
Is "C zero" something that you've removed?  - I don't see it anywhere.
2) Later you have a conditional assembly sequence:
Code: [Select]
#if 0
 // The compiler normally generates sts instructions for setting
 // up I/O space registers. But that takes 6 bytes per register.
 // This code can do it in 2, with an overhead of 20 bytes.
 // This starts to pay off when initialising 6 or more registers
 __asm__ volatile (
   "ldi r30,lo8(init_table)\n"
   "ldi r31,hi8(init_table)\n"
   [addr5]"i"(_SFR_MEM_ADDR(UBRR0L)), [val5]"i"((F_CPU + BAUD_RATE * 4L) / (BAUD_RATE * 8L) - 1)
#else
 // Set up Timer 1 for timeout counter
 TCCR1B = _BV(CS12) | _BV(CS10); // div 1024
 UCSR0A = _BV(U2X0); //Double speed mode USART0
I take it the #else block is used and not the #if 0?
3) does the "adaboot mod" jump directly to the app on power on or unless reset is pressed?
4) How long will the loader wait before giving up and running the app anyway if there's no host input and how is that controlled?  Similarly, how does the loader know the input is done?
Thanks again for a highly readable module and i hope you don't mind the questions.
Cathedrow
bill2009: Taking your questions in order.
1) Maybe I should rephrase. "The language 'C' initialises to zero ...".
2) Yes, the block of assembly language is not used. However, it took a lot of effort to write, and if one more register is initialised, it starts to save memory. So I've left it in the source code in case it becomes useful.
3) Adaboot jumps straight to the application if a watchdog event has occurred. Adaboot is documented here: http://www.ladyada.net/library/arduino/bootloader.html
4) The bootloader jumps to the main app when getch() times out, after 500ms. It also jumps to the main app immediately on any bootloader protocol error, or when programming completes.
Programming is complete when the bootloader receives the STK_LEAVE_PROGMODE message - but it must send acknowledgement before jumping to the main app.
mowcius
Quote
Yeah, had forgotten that as I have never tried it. Maybe I will try it then :)
Mowcius
des3maisons
". . . bootloader for 168 and 328 . . ."
What about the 1280 (Arduino Mega)?
mowcius
Well because it is a different type of chip, it would require another bootloader as far as understand it. The 168 and 328 are phsically identical with the same number of pins etc but the 1280 is completely different with 2 hardware serial ports and 54 I/O pins...
Mowcius
Cathedrow
Vintage: The 1280 (Mega) requires changes to the codebase as many registers work in different ways. The intent was to publish once the majority of Arduinos were supported. However, I plan to extend support to the Mega at a later date.
bohne
Peter, thank you for this great bootloader!
Currently I am redesigning LumiNet and I think the biggest problem is that I use my own bootloader on the attiny chips...
I would love to see attiny support in the main distribution and a stk500-compatible bootloader is the missing link at the moment.
Maybe you can help? One problem with attinys is that they don't have a bootloader section... the other problem is that most of them don't have a U(S)ART. I appreciate all ideas and hints here or in the LumiNet Thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254
http://www.dorkbot.de
http://www.luminet.cc
