Hello,
Je suis en train de construire un robot et lorsque j' upload le code la led orange reste fixe.
Savez-vous ce que cela signifie?
Merci
Hello,
Merci
PS, c'est une arduino Uno
Salut,
Il faudrait que l'on sache quel code utilises tu ??, pour savoir ce qui se passe.
Voici les parties de code :
#include <Kalman.h>
// Rutine for repeat part of the code every X miliseconds
#define runEvery(t) for (static long _lasttime;\
(uint16_t)((uint16_t)millis() - _lasttime) >= (t);\
_lasttime += (t))
//Set up a timer Variable
uint32_t timer;
double InputRoll; // Roll angle value
double InitialRoll; // Roll initial angle
timer = micros(); // Initialize timer
InitSensors(); // Initialize sensors
InitMotors(); // Initialize motors
delay(1000); // Wait until sensors be ready
InitialValues(); // Get the initial angle values
SetSetpoint(0); // Set the PID setpoint to 0
double RollAngle =0; // Roll angle variable
runEvery(10){ // Exetutes this part of the code every 10 miliseconds -> 100Hz
RollAngle = 0.98* (RollAngle + getDGyroRoll()) + 0.02 * (getAccelRoll());
timer = micros(); // Reset the timer
MotorControl(Compute(RollAngle-InitialRoll)); // Sends the real roll angle -> Roll - InitialRoll
ReceiveData(); // Checks Serial for incoming data
// This function is used to debug the robot, changig the set
// value of the PID
void ReceiveData(){
if (Serial.available()){
char a = Serial.read();
switch (a){
case 'q':
SetSetpoint(GetSetPoint()+0.01);
case 'w':
SetSetpoint(GetSetPoint()-0.01);
case 'e':
SetSetpoint(GetSetPoint()+0.1);
case 'r':
SetSetpoint(GetSetPoint()-0.1);
case 's':
InitialRoll = RollAngle;
Show(RollAngle);
// Show data via serial port
void Show(double a){
Serial.print("DATOS: ");
Serial.print("Initial Roll: ");
Serial.print(InitialRoll);
Serial.print("Roll: ");
Serial.print(a);
Serial.print("Real Roll: ");
Serial.println(RollAngle-InitialRoll);
// PArtie 2 :
// Motor Pins
int enablea = 3;
int enableb = 9;
int a1 = 5;
int a2 = 4;
int b1 = 10;
int b2 = 11;
// Prueba set point
double distancia = 0;
void InitMotors(){
// Set pins as outputs
pinMode(enablea, OUTPUT);
pinMode(enableb, OUTPUT);
pinMode(a1, OUTPUT);
pinMode(a2, OUTPUT);
pinMode(b1, OUTPUT);
pinMode(b2, OUTPUT);
// Set direction to none direction
digitalWrite(a1,HIGH);
digitalWrite(a2,HIGH);
digitalWrite(b1,HIGH);
digitalWrite(b2,HIGH);
void MotorControl(double out){
// Sets direction
if (out > 0){ // forward
digitalWrite(a2,LOW);
digitalWrite(b1,LOW);
}else{ // backward
digitalWrite(a1,LOW);
digitalWrite(b2,LOW);
byte vel = abs(out); // Absolute value of velocity
// Checks velocity fits the max ouptut range
if (vel<0)
vel=0;
if (vel > 255)
vel=255;
// Writes the PWM
analogWrite(enablea,vel);
analogWrite(enableb,vel);
// PArtie 3 :
// PID variables
int outMax = 255;
int outMin = -255;
float lastInput = 0;
double ITerm =0;
// PID constants
// You can change this values to adjust the control
double kp = 100; // Proportional value
double ki = 2; // Integral value
double kd = 0; // Derivative value
double Setpoint = 0; // Initial setpoint is 0
// Calculates the PID output
double Compute(double input)
double error = Setpoint - input;
ITerm+= (ki * error);
if(ITerm > outMax) ITerm= outMax;
else if(ITerm < outMin) ITerm= outMin;
double dInput = (input - lastInput);
// Compute PID Output
double output = kp * error + ITerm + kd * dInput;
if(output > outMax) output = outMax;
else if(output < outMin) output = outMin;
// Remember some variables for next time
lastInput = input;
return output;
// Seters and geters for Setpoint
void SetSetpoint(double d){
Setpoint = d;
double GetSetPoint(){
return Setpoint;
La dernière partie du code arrive dans 5 minutes.
En attendant voici une photo de la carte :
dernière partie du code :
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
// Gyro variables
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int L3G4200D_Address = 105;
// Accel
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
//Set up accelerometer variables
float accBiasX, accBiasY, accBiasZ;
float accAngleX, accAngleY;
double accRoll = 0;
//Set up gyroscope variables
float gyroBiasX, gyroBiasY, gyroBiasZ;
float gyroRateX, gyroRateY, gyroRateZ;
float gyroRoll = 0;
//double gyro_sensitivity = 70; //From datasheet, depends on Scale, 2000DPS = 70, 500DPS = 17.5, 250DPS = 8.75.
// Gyro Variables
int x;
int y;
int z;
void InitSensors(){
Wire.begin(); // Initialize I2C
// ¿200?
setupL3G4200D(2000); // Configure L3G4200 - 250, 500 or 2000 deg/sec
delay(1500);
if(!accel.begin()) // Initialize Accelerometer
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
accel.setRange(ADXL345_RANGE_2_G); // Configure accel
sensors_event_t event; // Variable for accel data
// Calculate bias for the Gyro and accel, the values it gives when it's not moving
// You have to keep the robot vertically and static for a few seconds
for(int i=1; i < 100; i++){ // Takes 100 values to get more precision
getGyroValues(); // Get gyro data
gyroBiasX += (int)x;
gyroBiasY += (int)y;
gyroBiasZ += (int)z;
accel.getEvent(&event); // Get accel data
accBiasX += event.acceleration.x;
accBiasY += event.acceleration.y;
accBiasZ += event.acceleration.z;
delay(1);
// Final bias values for every axis
gyroBiasX = gyroBiasX / 100;
gyroBiasY = gyroBiasY / 100;
gyroBiasZ = gyroBiasZ / 100;
accBiasX = accBiasX / 100;
accBiasY = accBiasY / 100;
accBiasZ = accBiasZ / 100;
//Get Starting Pitch and Roll
accRoll = (atan2(event.acceleration.y,-event.acceleration.z)+PI)*RAD_TO_DEG;
if (accRoll <= 360 & accRoll >= 180){
accRoll = accRoll - 360;
//gyroRoll = accRoll;
void InitialValues(){
// Accelerometer
double InitialAngle = 0;
double dGyro = 0;
accRoll = (atan2(event.acceleration.y-accBiasY,-(event.acceleration.z-accBiasZ))+PI)*RAD_TO_DEG;
getGyroValues();
gyroRateX = ((int)x - gyroBiasX)*.07;
dGyro = gyroRateX * ((double)(micros() - timer)/1000000);
InitialAngle = 0.98* (InitialAngle + dGyro) + 0.02 * (accRoll);
timer = micros();
delay(1);
InitialRoll = InitialAngle;
Serial.print("Roll Inicial: ");
Serial.println(InitialRoll);
// Roll from accelerometer
double getAccelRoll(){
accRoll = (atan2(event.acceleration.y-accBiasY,-(event.acceleration.z-accBiasZ))+PI)*RAD_TO_DEG; // Calculate the value of the angle
return accRoll;
// Roll from gyroscope
double getGyroRoll(){
getGyroValues(); // Get values from gyro
// read raw angular velocity measurements from device
gyroRateX = -((int)x - gyroBiasX)*.07;
//gyroRateY = -((int)y - gyroBiasY)*.07;
//gyroRateZ = ((int)z - gyroBiasZ)*.07;
gyroRoll += gyroRateX * ((double)(micros() - timer)/1000000);
return gyroRoll;
// Angular velocity of Roll by gyroscope
double getDGyroRoll(){
double dgyroRoll = gyroRateX * ((double)(micros() - timer)/1000000);
return dgyroRoll;
////////////// Gyro Sensor Code //////////////////
// This part of code if from Jim Lindblom of Sparkfun's code
// used for read the data from the gyro sensor: L3G4200D
void getGyroValues(){
byte xMSB = readRegister(L3G4200D_Address, 0x29);
byte xLSB = readRegister(L3G4200D_Address, 0x28);
x = ((xMSB << 8) | xLSB);
byte yMSB = readRegister(L3G4200D_Address, 0x2B);
byte yLSB = readRegister(L3G4200D_Address, 0x2A);
y = ((yMSB << 8) | yLSB);
byte zMSB = readRegister(L3G4200D_Address, 0x2D);
byte zLSB = readRegister(L3G4200D_Address, 0x2C);
z = ((zMSB << 8) | zLSB);
int setupL3G4200D(int scale){
//From Jim Lindblom of Sparkfun's code
// Enable x, y, z and turn off power down:
writeRegister(L3G4200D_Address, CTRL_REG1, 0b00001111);
// If you'd like to adjust/use the HPF, you can edit the line below to configure CTRL_REG2:
writeRegister(L3G4200D_Address, CTRL_REG2, 0b00000000);
// Configure CTRL_REG3 to generate data ready interrupt on INT2
// No interrupts used on INT1, if you'd like to configure INT1
// or INT2 otherwise, consult the datasheet:
writeRegister(L3G4200D_Address, CTRL_REG3, 0b00001000);
// CTRL_REG4 controls the full-scale range, among other things:
if(scale == 250){
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00000000);
}else if(scale == 500){
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00010000);
}else{
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00110000);
// CTRL_REG5 controls high-pass filtering of outputs, use it
// if you'd like:
writeRegister(L3G4200D_Address, CTRL_REG5, 0b00000000);
void writeRegister(int deviceAddress, byte address, byte val) {
Wire.beginTransmission(deviceAddress); // start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); // end transmission
int readRegister(int deviceAddress, byte address){
int v;
Wire.write(address); // register to read
Wire.requestFrom(deviceAddress, 1); // read a byte
while(!Wire.available()) {
// waiting
v = Wire.read();
return v;
